5 members (TBM, sewin, BLUE+4, +8Rich, John V6), 233 guests, and 37 robots.
+8Rich 99
John V6 55
Topics49,908
Posts838,116
#622186 11/03/20 07:02 PM
MGDave Offline OP
Started to replace the rear brake cylinders today. Removed the R/H rear drum and found the rear brake lining had become detached and I don't have a spare set of shoes on hand.
Does anyone know the part number and a recommended supplier?
Dave
98 +8 Corsa Red
74 MGB Red
Here you go- just give your local Motor Factors the number and they will cross reference it. Rear brakes
Or BHM always have some in stock BHM in stock.
Delphi/Lockheed LS1311
Springs etc
Try these brake part numbers,
http://www.talkmorgan.com/ubbthread...rad-models-brake-part-numbers#Post613595
I have used these parts recently and they were identical to the original parts I took off, so I can say from experience they are correct. You can use the numbers to cross reference.
1994 +8, BMW Calypso Red.
How do you open the boot?
Make sure the registration on the cup washers on the steady springs are good as when I replaced my cylinders and shoes a few years back one of them let go and locked the back axle solid, luckily I was backing out of my garage at the time it might not have been so funny at speed, nearly a Plus Six moment hide.
On my 1994 +8 the rear brake shoes are Mintex MLR67.
MGDave Offline OP
Thanks to all for your assistance, parts are now on order. After scouring the internet using every cross reference imaginable I could only find one vendor in North America who carried the +8 shoes. Thank goodness.
Dave
98 +8 Corsa Red
74 MGB Red
found these on the dreaded ebay
https://www.ebay.co.uk/itm/Brake-Shoes-GS6067-TRW-Set-GBS610-GBS651-GBS800-TKC294-9968570-Quality-New/233528889193?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
they claim to fit post 93 plus 8, mine is 94 but none of the part numbers seem to match???
link doesn't work so ebay item number 233528889193
If it is only the shoe lining that is worn or damaged then it might be worth typing in " BRAKE SHOE RELIGHNING" into your search engine... ?
Good luck in your search.
Brake shoes It'll save time in the long run and help a good dealer out they need all the help we can give them right now thumbs.
