8 members (KennyW, TalkMorgan, Luddite, John Winn, DJC, stumog, How, Graham, G4FUJ),
415
83
Topics49,857
Posts837,462
Posts: 1,415 |
Wow that looks stiff Simon. How did it compare to a regular trad ? Regular trad has a torsional stiffness in the 100's of lbs/degree ![[Linked Image]](https://www.tm-img.com/images/2020/03/28/74409964_10156344262572038_6161606391178985472_n.jpg) The calculated stiffness of the Class A chassis was in the order of 4800lbs/degree So stiffer than an Elise chassis, stiffer than an Aero Mk1 (which incidentally was the stiffest of the Aero variants), probably stiffer than a CX chassis too... Simon @ Sifab.co.uk sifabtemporary@gmail.com
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 1,415 |
This is a combined bolt in sump baffle and windage tray for the TR engined +4’s As the drivers are pushing harder than ever these days, they are starting to see oil surge when cornering on track The standard oil pick up on TR engine is a long sock like gauze, running along the bottom of the sump pan. It’s size makes it impossible to adequately battle the sump, so we designed a new pickup, that bolts directly to the bottom of the oil pump. We had to get these 5 axis machined because of some of the geometry of the part The new pick up allows for a much smaller area to be baffled with one way trapdoors ![[Linked Image]](https://www.tm-img.com/images/2020/03/21/8D1FBED3-A133-40F0-AC0F-68B1B7B44761.jpg) An old aluminium sump was 3d scanned and then sectioned to check for proper clearance Simon @ Sifab.co.uk Sifabtemporary @ gmail.com
Simon @ Sifab.co.uk
Posts: 1,415 |
To stop the quite frankly shocking images of the neoprene king and Kev getting it on that everyone’s got stuck in the heads.... Have a picture of an aluminium oil catch tank for a TR +4 ![[Linked Image]](https://www.tm-img.com/images/2020/03/21/0A89EE21-963A-4C2F-8235-5BF688F164ED.jpg) There, isn’t that much nicer Simon @ Sifab.co.uk Sifabtemporary @gmail.com
Simon @ Sifab.co.uk
Posts: 27,810 Likes: 749
Posts: 27,810 Likes: 749 |
Much nicer. Thanks for the brain sanitiser.
Posts: 5,465 Likes: 171
Posts: 5,465 Likes: 171 |
Thanks Simon,
That is helping. I might be able to sleep tonight now.
Posts: 2,310 Likes: 5
Posts: 2,310 Likes: 5 |
Simon
could you make an alloy catheter with aeroquipe type leads for those long journeys in my P4SS ?
Posts: 1,415 |
Simon
could you make an alloy catheter with aeroquipe type leads for those long journeys in my P4SS ? No problem, although welding the relevant adapter on to you might make you squeak a bit.... And in this instance you spelled P*SS wrong 🤣 Simon @ Sifab.co.uk Sifabtemporary @ gmail.com
Simon @ Sifab.co.uk
Posts: 1,415 |
We’re printing mask components for the NHS and other front line workers In PETG material so they can be autoclaved or washed in boiling water after use ![[Linked Image]](https://www.tm-img.com/images/2020/04/02/93A81BB1-D46E-49DA-99A8-3AFCB0D64830.jpg) A local engineering consultancy is coordinating all the micro manufacturers It’s like all the little boats going to Dunkirk! Simon @ Sifab.co.uk Sifabtemporary @ gmail.co.uk
Simon @ Sifab.co.uk
Posts: 8,672 Likes: 489
Posts: 8,672 Likes: 489 |
Well done Simon  Mrs M may end up wearing one of those
