7 members (chanteclair, HeadlessBlue, DavidR, Graham, G4FUJ, MATTMOG, John07, Lordofthewings), 315 guests, and 40 robots.
+8Rich 64
Adam12 62
John V6 57
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,319
Members9,215
Page 7 of 26 1 2 5 6 7 8 9 25 26
SFG #627371 01/04/20 10:11 AM
E
E
It should be easy to check and see if you have this switch fitted, while using the throttle with the right foot, gently apply the brake with the left foot, the brake should override the throttle cutting off the fuel, when the brake is released the fuel will flow and the throttle work again.
Most cars have this feature (im sure my roadster, plus4 did this) my tin tops do.
2017 Mercedes Benz SLC 200 AMG.
2019 Mercedes Benz GLA 200 AMG
Now Ex-Mogger!
Originally Posted by +8Rich
It's clearer in Uncle Melvyn's image Brake switch adjustment.
a level of adjustment is a basic requirement.
Richard, you are correct, notworthy the thin folded backnuts on the original looked too flimsy to be actual nuts to me
I've played with similar in a previous life so unfair advantage Jon thumbs
2009 4/4 Henrietta
1993 Connaught Green +8 prev
SFG #627437 01/04/20 01:05 PM
SFG Offline OP
I don’t mind the loom diagram. Takes me back to when I did the wiring looms for Gen-sets (1978)
SFG
2012 4/4 Sport
SFG #627863 03/04/20 11:21 AM
SFG Offline OP
Update: the replacement switch arrived from MR (thanks for that).
You can see that the terminals fit nicely on the new switch
Unfortunately the terminal insulators are like this
So I have to cut away the sides of the switch like this. Nothing’s ever easy
Now I compare the two switches, and the new one has a simple back but that won’t go to the bottom of the thread, so I swap the old skeleton back nut, and hey presto, it looks like I won’t need adjustment.
The end nut is a knurled ring , which I don’t trust, so I put the new back nut on the front. Genius. I can secure it with a spanner
So it’s all back together
Interesting that whoever last fitted the guard plate is a Wellings disciple.
I was about to replace it (I have got some neoprene!) but I decided it might be an original Wellings feature complete with the patina of age, to its better to conserve than replace. I must make a note in case I lose marks for it at the next Concours.
The whole point of this ramble (someone else can provide the synopsis) is that had to make a new tool to hold the brake pedal back, which will find pride of place on my tool board. I am willing to licence the design for use but others, but I am going to keep the intellectual property to supplement my pension.
I feel very sorry for anyone who has read all this, it just shows what you have been reduced to during your self isolation!
Now, has it cured the power loss problem? I don’t know. But I did clean the floor mat, which is where I started!
SFG
2012 4/4 Sport
SFG #627871 03/04/20 11:36 AM
Looks like a result, you could also wrap the slightly bodged switch end when the spades are fitted, with self amalgamating tape, which will insulate & retain it all together
SFG #627874 03/04/20 11:50 AM
Ooohhh, that neoprene needs replacing...…………….
SFG #627877 03/04/20 11:58 AM
First pic displays your full name and address .... possible issue there ....might be wise to delete, crop the pic and re-post that one
Image #627899 03/04/20 12:48 PM
SFG Offline OP
Crikey, you can’t be too careful these days. 👍
SFG
2012 4/4 Sport
DaveW #627901 03/04/20 12:51 PM
SFG Offline OP
No! It’s an example of the factory’s hand-crafting skills
SFG
2012 4/4 Sport
