1 members (Silverlady),
278
Topics48,345
Posts813,037
Posts: 17 |
Hallo. I bought two weeks ago an Morgan 4/4, RHD. build 1981. When I looked under the dashboard, i saw this lever. For what is it used? Thanks in advanced Bernd ![[Linked Image]](https://i.imgur.com/aCEpK8K.png) ![[Linked Image]](https://i.imgur.com/Zi9mIJz.png)
Morgan 4/4, 4 Sider RHD, Build 1981
Posts: 28,416 Likes: 178
Posts: 28,416 Likes: 178 |
Opens/closes the water valve for the heater.
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
Posts: 975 Likes: 20
Posts: 975 Likes: 20 |
It takes while to notice the effect of this knob being in/out on the valve’s position and temperature.
2025 Plus Six - 1909 2009 Roadster 1983 4/4 4str Board member Morgan Sports Car Club Holland ('21)
Posts: 17 |
Thanks Graham and BertR.
Bernd
Posts: 17 |
Posts: 4,607 Likes: 193
Posts: 4,607 Likes: 193 |
Bernd, Given the age of your car, it might be advisable not to make use of that valve if it is original, as the seal may have gone hard and if it is moved there is a chance you might cause a leak at the valve..?
Looking at the "lever" it seems to be of the type that has indentations on it`s shaft, which were generally used to help gauge and adjust the amount of flow of hot water through the heater as the indentations could be felt as the cable/lever was operated..
Looking at the position of the shaft in the photograph, it seems that the water supply to your heater is shut off, thus if you put the blower on it will blow cold, even when the engine is warm...?
Posts: 1,701 Likes: 105
Posts: 1,701 Likes: 105 |
I think that out means closed, so no heater on, as is in my 1990 4/4. But it makes not not much difference, certainly not directly after pushing or pulling it. It makes me even after more thans 25 years of driving this Morgan a bit confused from time-to-time!🇬🇧🤔🤫
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
There have been both Ruut. All three of my Morgans Out was off, In was on. However I know there are a number here where it is the opposite way around!  They are, after all, Morgan cars!
Posts: 2,041 Likes: 71
Posts: 2,041 Likes: 71 |
There have been both Ruut. All three of my Morgans Out was off, In was on. However I know there are a number here where it is the opposite way around!  They are, after all, Morgan cars!  The actress said to the Bishop when its out its in and when its in its out. My 94 +8 is one of those that is the other way round.
Bruce 1964 4/4 Series V Comp (Megan) 1994 +8 (Maurice) 2013 M3W (Olga)
Posts: 174 |
I always find that in cold weather the physical effort of pushing and pulling it is enough to warm me up. I've never found that it actually does anything.
