2 members (Ian B, ScotiaSteve),
310
105
Topics49,860
Posts837,485
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
Posts: 1,575 Likes: 55
Posts: 1,575 Likes: 55 |
If you've got an iPad or a Mac of any sort, you can simply record and loop a region in GarageBand. I've been doing a lot of recording for our band recently and stumbled across this use almost accidentally when I was working out a backing for a verse section in a song. You also get to see a visual representation and can adjust the region on the software. You also have a variety of in-built "drummers" or you can create your own drum parts.
Morgan Plus 4 Royal Enfield Classic 350 Brompton M6L Giant TCX Advanced
Posts: 809 Likes: 59
Posts: 809 Likes: 59 |
But the looper I use most often is the Digitech Trio+ 'Band in a box' pedal. This is brilliant for playing with yourself (ooer missus) as it creates a bass line and drum accompaniment from a chord progression you give it, then you can loop and overdub a separate accompaniment and noodle a solo part over the top. As you can imagine, without being able to play with anyone else I'm using it an awful lot at the moment.
Do you think this looper would be a benefit to a bass player? The drum part sounds great, but is there a guitar accompaniment as well?
Posts: 2,222 Likes: 182
Posts: 2,222 Likes: 182 |
Just seen this post. I would go for a Boss Pedal they do a number of different ones which would match your needs and price, personally I use the Boss RC-1 Loop Station.
Do you think this looper would be a benefit to a bass player? The drum part sounds great, but is there a guitar accompaniment as well? There's no guitar accompaniment on the Trio+, and so I'd recommend either the Boss RC-3 (simple) or the RC-10r (better drum machine) for use with a bass.
Posts: 467 Likes: 1
Posts: 467 Likes: 1 |
Fox terrier - Thanks for the tip on using looper in Garageband, it would be ideal solution. I have an ipad but struggle with GarageBand (garage anything - not good for a morgan owner). Will investigate further (maybe even look at instruction manual). Do you use speakers or phones?
1997 +8
Posts: 467 Likes: 1
Thanks again for all the looper responses. I knew I could rely on this community to come up with a number of options. Cheers, Nick
1997 +8
