7 members (BobtheTrain, Craig Jezz, TalkMorgan, GrumpyPa, cerealsurfer, TeddyAds, MartinB60), 340 guests, and 88 robots.
Sagging Hood
Topics49,859
Posts837,478
Originally Posted by Taffmog
I’ve been trying to learn the guitar for about 55 years! WTF is a looper pedal ? 🧐
I'd say that if there's one pedal that's absolutely indispensable for a guitarist who mainly plays alone, it's a loop pedal. Here's Justin Sandercote explaiining what they are all about:
And the Trio+ that Nick and I use is demo'ed here, playing a slow blues which is the kind of stuff that I generally do with it:
If you've got an iPad or a Mac of any sort, you can simply record and loop a region in GarageBand. I've been doing a lot of recording for our band recently and stumbled across this use almost accidentally when I was working out a backing for a verse section in a song. You also get to see a visual representation and can adjust the region on the software. You also have a variety of in-built "drummers" or you can create your own drum parts.
Morgan Plus 4
Royal Enfield Classic 350
Brompton M6L
Giant TCX Advanced
Originally Posted by Hamwich
But the looper I use most often is the Digitech Trio+ 'Band in a box' pedal. This is brilliant for playing with yourself (ooer missus) as it creates a bass line and drum accompaniment from a chord progression you give it, then you can loop and overdub a separate accompaniment and noodle a solo part over the top. As you can imagine, without being able to play with anyone else I'm using it an awful lot at the moment.
Do you think this looper would be a benefit to a bass player? The drum part sounds great, but is there a guitar accompaniment as well?
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
Just seen this post. I would go for a Boss Pedal they do a number of different ones which would match your needs and price, personally I use the Boss RC-1 Loop Station.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
There's no guitar accompaniment on the Trio+, and so I'd recommend either the Boss RC-3 (simple) or the RC-10r (better drum machine) for use with a bass.
Nick55 Offline OP
Fox terrier - Thanks for the tip on using looper in Garageband, it would be ideal solution. I have an ipad but struggle with GarageBand (garage anything - not good for a morgan owner). Will investigate further (maybe even look at instruction manual). Do you use speakers or phones?
1997 +8
Nick55 Offline OP
Thanks again for all the looper responses. I knew I could rely on this community to come up with a number of options. Cheers, Nick
1997 +8
