1 members (+8Rich), 312 guests, and 90 robots.
+8Rich 77
Topics49,870
Posts837,667
Rudolf
So my solution for the screws was to replace all but the one at the back, which is at an angle, with stainless steel dome headed bolts into some T nuts.
I have done the same for the cover over the battery aperture but with shorter bolts.
Tim
Plus 4 2018
Good idea but how well does the plywood shelf now sit and latch down, on top of those bolt heads?
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Doug, my shelf sits a little proud anyway because I have put a thin sheet of neoprene foam on the back. Just means I had to slacken off the screws on the latches half a turn
Tim
Plus 4 2018
Be careful if you have screws holding the battery cover on. A dealer put a longer screw onto my car, it went into the main positive feed and caused a short with a cable I use to lock on luggage on the rear shelf.
The carpets caught fire but fortunately I saved the car.
Thanks Tim.
Doug
1958 Triton 650
