1 members (Saxonian), 280 guests, and 67 robots.
+8Rich 77
Topics49,870
Posts837,668
Rudolf
#629553 10/04/20 12:34 PM
So today's lock down task:
I decided to remove the tool tray to inspect underneath. First thing I discovered was the the two screw at the front just went round and round, appears they have snapped off
So I will have to replace those.
What I discovered was that the nearside handbrake cable went between the shock and the mounting pole, this means a tight turn off the back of the hub and then signs of chaffing on the extra rubber around the cable (car has done less then 10,000 miles)
So I decided to reroute the cable around the other side of the mounting pole, which to my inexpert eye looks much better.
What next?
I know clean up the battery terminals.
Tim
Plus 4 2018
Tim & that is the routing as it should be.
When you next remove the off side rear wheel, have a close look at the handbrake cable as it curves down towards the brake drum. Splitting of the outer sheath at this point is a common issue and eventually results in rusted, seized or even broken inner cable. I wrapped mine in denso tape in this area.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
About the screws: Same on my car!
Two fake screws fixed in the air .... :doh
Probably caused by being screwed directly into the ash frame with a power screwdriver and no pilot hole. Screws made from cheese doesn't help either. Replace with stainless but you won't be able to use same hole location.
[/quote]
Probably caused by being screwed directly into the ash frame with a power screwdriver and no pilot hole. Screws made from cheese doesn't help either. Replace with stainless but you won't be able to use same hole location. [/quote]
That would be fine but at my car this 2 screws have been cut and there was no ash frame at this place just "air".
I didn't find a hole in this area of the In the ash frame either
So I think someone at MMC made some screwdummies!
rofl
TBM Offline
I carry a box of cooking matches in my car (safety ones of course). If I ever get a loose wood screw while out and about, a couple of neatly trimmed matches poked in the whole make a suitable fix and give the screw plenty to bite on. If I'm at home, I use a touch of woodglue to help.
I used to use matches too.
But since I own the MORGAN and because I am sometimes a perfectionist, I have bought various round rods made of beech wood that I use as wooden dowels.
That is up market. I follow the trick taught me by my Grandfather of using a match(es) & if available wood glue.
Broken off screws can be extracted using a hand pin chuck, but it's time consuming. Make a hole then tap a modellers three faced file into the end and draw out by unscrewing with pliers...…………...
Where possible I try to fill holes with a sawdust/wood glue mix, which can then be re-drilled……..
I also use matches...and ash always needs a pilot hole...…….try drilling it and it's exceptionally hard.
