4 members (Davetherave, Mike D, GrumpyPa, TalkMorgan), 300 guests, and 31 robots.
+8Rich 101
John V6 66
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,919
Posts838,267
Smed., Spanner Juggler
PhilRoyle #633531 28/04/20 12:04 PM
Thanks all - I will investigate when it stops raining.
PhilRoyle #633571 28/04/20 03:04 PM
1972 4/4 2 Seater
PhilRoyle #633601 28/04/20 05:31 PM
Gizmo Hi!..
Originally, wood screws did all of the hinge retaining/locating on my car, '69 4/4.
After experiencing the futility of having to re-tighten them at intervals,
I did what most others have done. Removed the wood screws, drilled a through-hole and used appropriately-sized
flat-head machine screws - nuts - washers/backing plates. Seems as though your car might have already had some of the
hinge-fixing hardware replaced.
cheers
Bert & B1800
PhilRoyle #633627 28/04/20 07:26 PM
Phil, Your car will have nuts on the back of the screws. You can normally nip up the ones on the door, without taking the door card off. The ones on the A post, go through the scuttle roll bar and have nuts behind. If possible hold the Allen key in the heads and tighten the nuts. Even half a turn on a few of them will make a big difference. You might need hinges in a few years but this should sort it for now. I saw your car recently and your wood work was fine šŸ˜‰
PhilRoyle #633636 28/04/20 07:58 PM
I think I have a pair of HOE hinge pins unused somewhere, but I’m in Scotland and they are in my garage in London. Worth trying a few of the dealers that are open they might have them, BHM, Rutter etc...
