7 members (TeddyAds, nick w, RobC, JMcL, TalkMorgan, RedThree, Liam1961),
296
92
Topics49,859
Posts837,469
Posts: 8,672 Likes: 489
Posts: 8,672 Likes: 489 |
Well done Kevin
What I'd really like is someone to develop a properly made Perspex version to fit the factory 'screen inserts
Where's Bonesie when you need him ?
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
Nice one Kevin  I wonder if the 'rods' will pull out, so you could adjust internally ? Yes, Hi Jon, the rods pull out and are about 12cm long on each side. The inside tube (created by bending the sheet round is so crude that it barely represents a circle. When I pulled one of the bars out it had a small sliver of wood jammed in there to create some extra friction. It is a disappointing bit of engineering, sourced by the dealer and so may not be an MMC part. I'm tempted to make up a set of my own from tinted perspex, using the same mountings and having a thumbscrew through the clamp to apply some pressure. Why dont you try the usual strip of grey transparent vinyl across the inside top of the windscreen. You could even have Kevin and ........ printed on it!
Posts: 922 Likes: 1
Posts: 922 Likes: 1 |
Nice one Kevin  I wonder if the 'rods' will pull out, so you could adjust internally ? Yes, Hi Jon, the rods pull out and are about 12cm long on each side. The inside tube (created by bending the sheet round is so crude that it barely represents a circle. When I pulled one of the bars out it had a small sliver of wood jammed in there to create some extra friction. It is a disappointing bit of engineering, sourced by the dealer and so may not be an MMC part. I'm tempted to make up a set of my own from tinted perspex, using the same mountings and having a thumbscrew through the clamp to apply some pressure. Why dont you try the usual strip of grey transparent vinyl across the inside top of the windscreen. You could even have Kevin and ........ printed on it!  Ha ha, yes her ladyship will enjoy that.
Kevin
Posts: 922 Likes: 1
Well done Kevin
Where's Bonesie when you need him ? I think a perspex unit would be good too, I looked , only briefly, for S/S fittings that might work from other applications - glass clamps etc. So far I haven't found anything and might keep that on the agenda. It needs the more advanced fettling skills of Bonesie, DaveW and others.
Kevin
Posts: 61 |
I have fitted perspex visors to my 2006 S1 Roadster, & I certainly don't posses the 'fettling skills' of Dave W etc! But was able to modify them to fit around the rear view mirror, just needed the fixings to suit the windscreen studs. There is a previous thread on here somewhere, they are advertised as Mini visors, available from c-t-sspares on e-bay in a number of colours
Regards Peter T 2015 Plus 4. Sport Ivory 2 seater.
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
Thanks for your advice, Island Mog. I have found these.
https://www.ebay.co.uk/itm/CLASSIC-AND-KIT-CAR-GREEN-PERSPEX-SUNVISOR-KIT-WITH-FRICTION-HINGES/153527530859?hash=item23bef4356b:g:9GoAAOSwiTNdA6YC
So I could drill the holes to meet the distance of the studs of the Morgan screen without having the additional holes of the Mini dimensions. Could you post a photo how it looks on your Series 1 Roadster? That would be very helpful. Thanks.
Posts: 528 |
If I recall correctly I simply peeled back the leather and squeezed the aluminium in a bit, I can't recall if I completely removed or only partially removed the rods. Still good after 65,000 kms I did grind back the flat ends of the rods to about the edge of the stand off spacers because if left to long they interfere with the action of the hood clip levers. I did the same. Took off the visors, removed rods, protected leather and put visor "tube" into vice and carefully squeezed at both end. Worked a treat!
Posts: 1,309 Likes: 5
Posts: 1,309 Likes: 5 |
Well done Kevin
Where's Bonesie when you need him ? More than happy to. Whats more, Id do the work for free !! it would cost you just the material price and postage. If anyone can get me an accurate 2d drawing Im happy to do some.
Bonesie Current stead -'The Captain' Black +4 'Life is like a garden, dig it' *Joe Dirt
Well done Kevin
Where's Bonesie when you need him ? More than happy to. Whats more, Id do the work for free !! it would cost you just the material price and postage. If anyone can get me an accurate 2d drawing Im happy to do some. Mr B, it's not the Perspex that's the issue. it's the invention of some really nice hinge mechanism that fits the factory 'screen studs I'm thinking a nice st steel channel with integral friction rod that we can bond the leading edge of the Perspex into ?
I'm just wondering if the original or other sun visors that are made of non-transparent material are perhaps healthier. The plexiglass lets UV light through and you feel protected without sunglasses. But the UV light is not good for the eyes?
