1 members (+8Rich),
290
70
Topics49,870
Posts837,668
Posts: 1,738 Likes: 56
Posts: 1,738 Likes: 56 |
Hi Bruce, The removable terminal nuts loosen just after a few drives. I use a drop of loctite to hold the plug terminals in place. Never had a problem since.
Andy
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
Hi Bruce, The removable terminal nuts loosen just after a few drives. I use a drop of loctite to hold the plug terminals in place. Never had a problem since. I did that after finding they were loose, where would we be without loctite!!
Posts: 121 |
Sounds like an ample amount of blue loctite should always be kept on hand.
2017 Terracotta 3-Wheeler + G56 Stage 1 (SOLD)
Posts: 775 Likes: 33
Posts: 775 Likes: 33 |
https://www.emcstandards.co.uk/never-use-liquid-threadlockers-on-any-electricaI’ve linked an article regarding the use of liquid threadblockers on electrical connections. Just be aware Loctite is an insulator not a conductor of electricity. Theoretically you might be diminishing your spark.
Posts: 1,947 |
Crimp the terminal nut in place?
I wondered about this too.
Why go through all that fuss? Just use a spark plug with a non removable terminal nut like the equivalent HD plug noted earlier in this thread.
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
Why go through all that fuss? Just use a spark plug with a non removable terminal nut like the equivalent HD plug noted earlier in this thread. that would be TOO easy LOL
I put a wee dab of Blue Loctite on the top of each plug just to be sure the roughness I was getting was at lower RPM. It did not help but it still ran fine at the higher rpms so I thought about fuel distribution and that lead me to the idea of a fuel system that distributes fuel to sack injector equally. Morgan Custom has such a product and it has the benefit of a fuel pressure regulator and a fuel filter BEFORE THE INJECTORS. Boy does it run more smoothly at the lower RPM!!! Just set the pressure where you want it and you are off to many more miles of smooth motoring. ![[Linked Image]](https://www.tm-img.com/images/2020/05/12/995B3174-D670-4C1B-B175-7DBA323B4EC3.jpg)
