2 members (gmcn, Pigiron),
190
52
Topics49,843
Posts837,336
Posts: 257 Likes: 3
Posts: 257 Likes: 3 |
I have read on here that removing the bobbins can be a challenge. Mine are intact but all have quite a few cracks on the surface. Having read that a few of you have had your pipes actually fall to the ground, am thinking prevention is worth the effort. However, mine are stretched at a decent angle, as if the top and bottom mounts are not well-aligned. Do others have this same fitment issue? Mine is a 2016. Any tips? And where are you sourcing your replacement bobbins? Cheers.
Aka Joejoe
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
No doubt the bobbin bolts are rusted on, so a hacksaw is called for. The chassis bracket is a not very artistic piece of bent metal , and, will be d to suit. You might find a slight rattle after re-fitting which I attribute to a slight misalignment at the flexible joint causing some contact. Calls for a bit more bending. Bobbins are a proprietary part, these might do https://www.manomano.co.uk/sanding-...8WXsvBtRXwHM7aY60-4r6b2kKyoaAuleEALw_wcB
SFG 2012 4/4 Sport
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
I think SFG has maybe given you the answer for a 4 wheel Morgan, you shouldn't have to hacksaw a 2016 M3W exhaust. The M3W the exhaust bobbins are not too tricky to replace and are accessible. You can usually align the exhaust better if you loosen the two header stud nuts to allow the headers to move slightly, tighten them up again once it is all in place and not stressing the mountings. You can also elongate the mounting holes to get better alignment. Replacement bobbins are very similar to Renault 25 items but a look on eBay will usually find something suitable at a fraction of the cost. They are M8 studs and about 25mm tall. I don't think a 2016 installation exhaust will have the early type mounts, it was the early ones that gave problems and sometimes allowed the pipes to hit the ground.
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
The left side will fit easier than the right. The mounting bracket for the exhaust on the right side did not account for the fact that the right cylinder is set back compared to the left so fitting can be a challenge. The newer bobbins are pretty good. The original stock bobbins from 2012 to ? were not fit for hot mounts. The new ones do a much better job.
Posts: 31 |
A good possible source for those in the US might be McMaster Carr. You can input the criteria that you are looking for to help narrow things down so it might be worth taking a look. I have ordered numerous items from them, including the bobbins to support my Plus 4 radiator, and have always been very pleased.
Rob
‘61 Plus 4
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
M3W bobbins are classic Mini exhaust bobbins, also used on Morgan radiators and many other applications.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 257 Likes: 3
Thanks for the input. Even though mine is a 2016, there is still some obvious mis-alignment as the bobbins look more like parallelograms than cylinders!
Aka Joejoe
Posts: 423 Likes: 2
Posts: 423 Likes: 2 |
I replaced my rubber bobbins with woven stainless steel made by www.kineticstructures.comI spoke with the owner and he built me a set for my three wheeler. specifications as follows Wire Mesh Bushing 304 stainless steel OD 1.40" ID 0.38" thickness 1.25" density 20% Quantity 4. I can not find my receipt, but I believe they were $50 for the set. I would have included a photograph, but I find the system to attach photos a bit cumbersome. Lance
Lance 1981 Plus 8 2016 Three Wheeler 2022 Corvette Stingray Convertible z51
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Lance you are being most kind in reference to photos.
I like the idea of stainless woven bobbins.
