0 members (), 434 guests, and 32 robots.
+8Rich 71
Adam12 69
Hamwich 53
9,215 Registered Users
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,372
Posts813,497
Members9,215
Winglad
Page 3 of 4 1 2 3 4
Originally Posted by Taffmog
Your rattle could be a loose drive belt, worth a check....
Thanks for the forewarning.
Visually it looks OK I mean it does not appear to have much slack.
How would I know if the drive belt is loose?
2017 Terracotta 3-Wheeler + G56 Stage 1 (SOLD)
A loose belt generally makes a banging noise on the overrun. From memory I think the recommendation is 10mm play in the belt, that's by pushing very hard on it.
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
Bcoupe, great description/explanation.
Looking up from underneath the car, this seems to be the bevel box drain:
I think I know how to go about this now.
This forum is so helpful. Thanks, everyone!
Raise the front of the car a bit to get all the oil out of the bb.
Fill on level.
Golden: I modified a hex drive that works wonders for my BB oil change. I am South of you in ELP, (TX, not CO). As I am technically challenged to figure out how to post pictures on the forum, you are welcome to PM me, and I will forward you the pics. Also, I wish to install the G56 Stage I, so I would appreciate exchanging your impressions.
Thank you
Originally Posted by m3w_golden_co
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx I have an annoying rattle that seems to be coming from behind the seatback ... might that be the dreaded bevel box noise?xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
I guess you have checked…. but I must insist that my rattle / rubbing noise came from a bad factory installation of the rear mudguard. Sorrry to repeat myself, but just in case...
www.speedymarmots.com
Piloto: I just sent you a PM. Thanks!
Javier:
The factory mudguard does not appear to be loose. I tried to move it and its screwed on pretty solid.
The rattle I am experiencing is at certain RPMs when there is just the right amount of vibration.
Under acceleration, I do not hear this rattle.
Marmota #638524 18/05/20 10:51 PM
On some cars, one of the roll over hoops has very little clearance to the bodywork which can cause a metal on metal noise at certain revs. Peel back the rubber roll hoop seals to check that the hoop tubes are centrally mounted in the bodywork apertures.
Andy
Page 3 of 4 1 2 3 4
