2 members (DJC, Socalm3w), 363 guests, and 39 robots.
+8Rich 93
Posts837,277
Hole saw
Found this on Ebay.
Originally Posted by rockabilly john
Hole saw
Found this on Ebay.
Added! Thank you.
2018 S&S 110th Beetleback
1934 MX4 Beetleback (in restoration)
1965 Corvette Coupe 327/350
Thank you Steve & Paul....added to procedures.....
Can anyone help me contact the Admin so I can delete the procedures Pic? I want to update it with all the suggestions.
Thank you.
I drilled out my front baffle, which is the most restrictive, look like the rear baffle.
It really woke the engine up!
kirkusblog.com
1952 Ford 8N
Updated procedures with a few pictures posted. Thank you all for the comments!
Is there a reason you guys used 25mm or a 38mm hole saw as opposed to a 40mm or a 44mm?
The front and rear baffles are 38mm anything larger would not fit.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Odd, a 44mm slides right inside the pipe comfortably.
If you look inside the pipe you should see that where the front and rear baffles are located the pipe is restricted so 44mm would be too big and damage the pipe, well at least on mine and I assume the others that have done a bafflectomy.
Bruce
2013 M3W (Olga)
I just took a 44mm out to the shop and it fits in one side and not the other, so the 38mm is for sure the best bet, you are correct👍
Did you wrap the bit to center it to start the cut? So the bit would not wobble on start?
