1 members (Socalm3w),
336
Posts837,277
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
Wrap some masking tape around the cutter so it is a nice sliding fit then give the extension a tap with a hammer to centre punch the baffle.
Remove the tape and resharpen the pilot drill then off you go.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Posts: 2,221 Likes: 181
Posts: 2,221 Likes: 181 |
I found the drill bit awkward to use and it was much easier to remove it just using the cutter with WD40 as a lubricant, applying light pressure to start the cut then letting the cutter do its business. I didn't need to wrap the cutter as 38mm was the size of the baffle and the cutter without the drill bit cuts it directly without any movement.
