15 members (Image, lez, Rex_tulips, B3MOG, Burgundymog, hugo, Ubiquitous, Sir Percival, Bishmog, High Hamster, mph, davewhite, OldSkrote, Lordofthewings, itsfrank666), 312 guests, and 49 robots.
Adam12 69
+8Rich 67
John V6 59
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,367
Posts813,404
Members9,215
Rbt Aero8, Salmon, stevends
Easy for me to say but can I suggest you stick with finding a solution to this problem. I'm sure there will be one.
Good luck thumbs
Looking at the JW Speaker web site, it describes the two-pole connector with the red and orange wires as "an extended harness that you will tuck down and plug into the Jeep’s factory turn signal plug".
On the Jeep JK those turn signal lamps also function as a parking lamp, so I assume that is what the "RED WIRE for position" does. Looks like there is an unused 3rd connector position on that plug which is presumably the ground for the Jeep turn signals, which have a 3 wire connector.
You should not need to connect the 'M3W OEM turn signal white ground wire' to anything, although it should be reasonable to also connect it to the 'BLACK WIRE for ground' as a backup ground path.
I would try connecting 12V positive to the red wire just to see if this helps, although that seems unlikely based on the JW Speaker instructions. If it does you'll need to use a source of ignition-on 12V as a permanent solution.
I'm interested to hear if you get this solved as I'm planning a LED upgrade of my M3W when I get the time...
2020 M3W
bcoupe Offline OP
I'll work some more on it this weekend! cheers
