0 members (), 341 guests, and 83 robots.
+8Rich 77
Topics49,870
Posts837,668
Rudolf
#640447 26/05/20 06:46 PM
Can anyone offer advice on removing both seats of my 1993 plus 4?
4 bolts, under the floor / chassis cross member. Easily done, with a spanner, but I replaced the bolts with Allen key head ones for easier removal in future
If you struggle to get a spanner on the bolt heads in the runners behind the seats a pair of small Mole (Vice) Grips are really helpful.
BR
Colin (sounds obvious but don’t forget the upper seat belt fixing on the seats backrest).
BR Colin
Seat belts shouldn't be a problem as they're mounted on the rear wheel arches and no connection to the seats.
My seats have six bolts that go trough the floor 4 at the front and 2 at the back
The big hole is for the nut from the front of the seat
Dirk
1993 Morgan +4 (Connaught Green)
2009 Mini Cooper D
2024 Mercedes GLC
1994 Ford Motorhome
Thanks Dirk. Are the frames mounted on wood?
Just had my seats out on 2011 roadster,looks the same.
Renewed all nuts bolts in stainless, the 4 rear ones being Allen head machine bolts as the heads fit nicely in the channels, the front ones keep as hex head as you can reach across with long ring spanner whilst undoing/fastening underneath.
MMC.
Yes they are. The originals are wedged with the thinnest end at the front but I've changed them to blocks of the same height so the seat leans more backwards and as a result I sit lower into the car.
See Photo's here http://www.talkmorgan.com/ubbthreads.php/topics/592778/driver-seat-upgrade
Dirk
2009 Mini Cooper D
2024 Mercedes GLC
1994 Ford Motorhome
