6 members (Montegue, Laurens, Bitsobrits, TalkMorgan, jbk, Luddite), 276 guests, and 80 robots.
+8Rich 86
Sagging Hood
Topics49,854
Posts837,459
Page 25 of 26 1 2 23 24 25 26
Originally Posted by RobCol
Ive noticed there are two brake pedal switches on mine too but don't know why either. Can anyone else tell us?
Are the brake lights still working with only one switch working? Its unlikely but could one switch be for the high level brake light? Easy to check for both I suppose.
If you replace the faulty switch I would take a photo of its placement before removing. I assume that both are adjusted the same amount.
Finally I would have thought that the brake light switch is a separate problem than the loss of power unless someone can explain otherwise!
Rob, the second switch is the stop fueling signal to the ECU when you brake.
This seems like a long time ago now and glad it helped in some way.
It was definitely a big help!
SFG #641054 29/05/20 04:09 PM
SFG Offline OP
However, why did it work properly for so long beforehand? My target is to get the switch back into operation: I think possibly switch adjustment, ecu needing reboot, or mapping issue.but I won’t bore everyone with all that.
Odd that I didn’t get a steer along the right lines from any official sources.
SFG
2012 4/4 Sport
SFG #641065 29/05/20 04:58 PM
I think someone suggested earlier that the if the brake pedal had been released suddenly on occasions then the adjustment or internal workings of the switch could have been affected. It could just be normal wear and tear that has brought on the problem or even a poor design of switch in the first place.
You would think that the dealers would be aware of the problem and how to set up and adjust the new switch.Failing this have you thought of contacting the service department at MMC when they return to work?
Rob
SFG #641098 29/05/20 07:39 PM
The way I see it. In my case, there were other actions taken before regarding this problem where I thought I had the solution because it worked for a few months. But it was always a random result. Now, with the switch, it's the first time that I was able to deliberately cause the error and also deliberately remove the error.
My old switch is definitely not good anymore. You can feel the button rubbing. It is possible that it still conducts current, but a) with loose contact and b) probably with slightly increased ohmic resistance. The control unit seems to be very sensitive and the full voltage must be switched through.
As I said before, you can drive well with bridged cable, without a switch. But you have to use a lot more brake power in the pedal, because without a switch the engine revs decrease much slower.
One more word about my new switch. It is exactly the right one. It has a knurled nut and a hexagon nut. The hexagon nut is on the side towards the driver. This hexagon nut is too thick! That's why the knob can't get close enough to the brake pedal. So instead of the hex nut I used the thinner washer that was on the driver side of the first original switch.
SFG, I would first realize this correct switch position and look. I would not question the mapping now when everything is working again. Otherwise it gets too complicated and now everything is on the home stretch.
To be perfectly honest, Stuart, I'd go a few weeks without a switch as it is now. Then you can be sure the mistake won't happen again. And after that time, you can think about putting the switch back in the right position.
SFG #641106 29/05/20 07:53 PM
I think it's not boring at all. For such topics the great TM forum is there and helpful. Sometimes a user is closer to the cause of a defect than an official garage is because of a long relationship with our car. And as I said, such a switch is a wearing part. It just gets worse over time until it doesn't work anymore.
SFG #641136 29/05/20 10:04 PM
SFG Offline OP
Except that a new switch didn’t cure it!
SFG
2012 4/4 Sport
SFG #641190 30/05/20 11:13 AM
is it only me...or was it actually the new coil pack that cured it, as suggested by Paul F a few threads back?
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
SFG #641225 30/05/20 02:46 PM
SFG Offline OP
It might have been, but only by cosmic osmosis. I didn’t fit it, because the screws were wrong thread, and I found I’d cured it before it was needed. Now I have a brand new NGK coil pack for sale.
SFG
2012 4/4 Sport
SFG #641455 31/05/20 03:45 PM
Personally, I'd keep it in the 'touring spares' pack
SFG #641472 31/05/20 04:49 PM
SFG Offline OP
Too heavy for that. I’d have to ditch 15 pairs of her shoes!
SFG
2012 4/4 Sport
