0 members (), 220 guests, and 87 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Page 1 of 5 1 2 3 4 5
Marian Offline OP
Hi.
Does anybody knows which pads will fit the "Caparo" brakes on my 2010 Plus4 (and where to order from)? I'd consider further modification for enhanced stopping power. Who can point me in the right direction?
Here in Switzerland any information on these parts is scarce.
Thanks,
Marian
Try Melvyn Rutter
Hi Marian,
the EBC GreenStuff is a recommendation thumbs
- but be VERY careful changing the pads: the fitting pins&clips are VERY vulnerable..... innocent
All the best - email me pls! cheers
drive 2015 Roadster 3.7
...just an addition: funny, but the brake pads for the current CAPARO´s are the same than the ones before!!! laugh2
The CAPARO Calipers could easily hold larger pads...... doh
Marian Offline OP
Hi Jochen,
where do I get EBC GreenStuff pads (on the continent)?
What do you mean, "pads for the current CAPARO´s are the same than the ones before"? Was there an update on the brakes on 2011 models I do not know of?
If the calipers could hold bigger pads, who knows where to start looking?
Aren't these CAPARO's renamed AP calipers? Are they sold as OEM equipment to any major car maker - or just low volume and kit car manufacturers?
Marian Offline OP
BTW: How come you had to fit new pad with this sort of mileage. You have taken it to the track, haven't you? scared flag
innocent.....
http://www.ebc-brakes.de/start.php4?page=car&PHPSESSID=2ff22d072d8fcceab5ea276500964e5b
And CAPARO doesn´t sell to "users", don´t even answer e-mails!
I didn´t succeed in sourcing ANY dealer/retailer, neither uk nor continent, who´d be able to sell original CAPARO Parts yet...
http://www.caparoapbraking.com/
And the brake pads used in the former 4-caliper calipers (Lockheed?) are the same then the currently fitted ones.
One also had to work over the original ( & the EBC´s too)pads, as their outer edge reached over the discs diameter!
South Wales Correspondent
Originally Posted By Marian
Hi Jochen,
The situation used to be that everything was under the AP banner ( in fact, originally it was AP Lockheed) They were based in Coventry.
The AP company was split up, and a separate high performance road car and racing division was created, called "AP Racing Limited". The AP Racing company was sold to Brembo, and in their (Brembo) published corporate structure, AP Racing Ltd are a 100% owned subsidiary of Brembo.
The lesser mortals of the former AP company were, I think, sold to the Rover Group, ( the story goes that this was to enable the continued supply for black cabs, and Range Rovers!) After a few more twists and turns, this is what ended up as Caparo AP
You can find the story here:
http://investing.businessweek.com/research/stocks/private/snapshot.asp?privcapId=27226484
That having been said, Caparo AP stuff is fitted as OEM to quite a few makes, including I think, Aston Martin.
Because of this, although you might find that the LOOK of the calipers has changed ( for example they might now be billet) there may be no difference in pad size)
To give you an example. I have AP ( old style) four pots on my 4/4 which is a 2000 car and I was wondering if there was any advantage in changing to the calipers as fitted to the current 4/4 Sport.
I might have been luckier than some other posters because actually spoke on the telephone to the guy at Caparo AP who was liaision with Morgan and he told me that the only advantages of swapping were: 1.the billets were better - looking 2. There would be a small saving in unsprung weight
So, I left them as they were ( but I did replace all hoses with Goodridge stainless braided items- which gave a small advantage. I also run 'Greenstuffs' I don't run EBC disks because they are prone to judder so I now stick with the original rotors
Mind you, it all pales in insignificance when I thinkabout the fact that my rear drums come off a Ford Transit! ooo
Cheers
PS Peter Mulberry does 'Hi-Spec' brake conversions for Morgans but I have no personal experience of how good or otherwise they mightbe
Another souce of good ideas is this guy:
http://www.bgdevelopments.co.uk/
Why not drop him an e-mail and see what he says re an upgrade?
GLLHG
