8 members (Laurens, Soleng, JJW, nick w, jbk, High Hamster, GrumpyPa, BobtheTrain), 267 guests, and 40 robots.
John V6 79
+8Rich 70
DaveW 68
9,203 Registered Users
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
Topics48,337
Posts812,930
Members9,203
toitoine
Page 2 of 6 1 2 3 4 5 6
The Roadsters shouldn't have rubbing issues because they have less wheel inset (wires) than the 4/4.
Having said that my current car has a very tight clearance whereas the previous Morgan to identical spec had no issues. I've ovalled the reaction bars at the bottom to gain a couple of mm.
Hi All
I tend to fit them below the the Spherical washer, as that is where they where designed to fit on a flat top King pin before domed top kingpins and spherical washers which are fitted to later Morgans.
Note
I have Had one Spherical Washer (concave part) explode on tightening the Oiler Bolt it dented the wall!.
Tyres rubbing Brake reaction bars are not a problem its only on a tight tern usually when parking.
Cain
Wolf Cafe Racer
4/4 Sport
Originally Posted by Cain
Hi All
Note
That does not sound good. How many people are driving round with the washer about to fail?
Each to their own, but unless you are up for track days or are into extremely spirited road driving with hard braking at the last moment, I really cannot see the point in brake reaction bars. Drilling holes in the chassis, bars rubbing the tyres, now the risk of fastenings exploding...
Maybe they are popular because they are cheap and can be fitted as a DIY job to achieve an “upgrade”...
End of rant!
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Deejay my 4/4 felt “wobbly” just braking moderately. The reaction bars solved it. Recommend by a highly respected morgan garage.
I'm not sure that it's the brake reaction bar so much as tightening the oiler bolt that stresses the spherical washer, is it? once it's done, I can't see how the presence of the BRB would per se increase the risk of failure?
I would agree that the brake reaction bars aren't necessary for normal driving, but I did find my car felt more secure when piling into corners under hard braking after I fitted mine. But as you say, chacun å son goût!
I thoroughly greased my shaped/conical washers (one thick one thin from memory) before fitting. I made the point earlier in this thread that they need to fit directly under the oiler bolt to allow them to settle into their natural and correct position by the action of the bolts shoulder bearing on them as it's tightened. I suspect when this doesn't happen you can expect Cain's experience.
Again from memory, the two washers are flat on one side and taper in thickness on the other. The two tapered surfaces are placed against each other and settle into a combined position to take up the tiny angular difference between the upper surface of the upper suspension support (plus bracketry in between) and the oiler bolt shoulder when screwed into the matching kingpin thread.
What on earth is this?
A thoroughly interesting and technically fascinating Morgan improvement thread without any reference to Dominic Cummings or government bashing
Is this allowed Bob?
BobJ Offline OP
Yes you're absolutely right - sorry Stewart. What was I thinking? Suitably admonished.... I'll get my coat getcoat
2017 4/4 80th Anniversary
Send for Doctor Morgan. He went very quiet recently!
2025 MG ZS EV aka Trigger
+1 break reaction bars (with Panhard Rod) great handling improvement on my 4/4
Craig Jezz
