Morgan Aero 8
3 members (SteveT, vincentvg, Strathaven), 188 guests, and 105 robots.
Topics49,848
Posts837,401
DazMog, The Impaler, tlchzj79
I have just bought an Aero 8 S1.
I think the tyre pressure monitoring system having a problem is so common that I can't find any recommendations in the forum as how to get it to the point that it works and is happy. Is this simply make sure all sensors are functioning correctly and do some sort of reset? Looks to be flashing up an error code E4.
Also the Mileometer looks to be flashing up the normal distance then going a little crazy flashing up all sorts of nonsense.
Cheers
Phil
A3RUO, a few bolts and we're done
Hi Phil
It seems that the tyre monitoring system is not very accurate and mine failed after it had done 5k miles. I never relied on it.
Same thing happened on my mileometer. It went away and luckily never appeared again.
regards
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
Thanks for your feedback. I'm okay with inaccurate but of course when it alarms that's annoying isn't it.
My hope is that I can sort of get these working for completeness sake as opposed to relying on them as being accurate in ant way.
Thanks
Phil
I know they're not 'integrated' as such but I have seen some very impressive wireless tyre pressure monitoring systems from a company called Tyrepal:
http://www.tyrepal.co.uk/
I don't think I've ever seen a report about manufacturer TPMS that don't throw up false readings/warnings!
