7 members (DaveW, Graham, G4FUJ, gomog, GrumpyPa, JohnHarris, Ruut Bianchi, BobtheTrain),
218
82
Topics49,848
Posts837,406
Posts: 20 |
I have just bought an Aero 8 S1.
I think the tyre pressure monitoring system having a problem is so common that I can't find any recommendations in the forum as how to get it to the point that it works and is happy. Is this simply make sure all sensors are functioning correctly and do some sort of reset? Looks to be flashing up an error code E4.
Also the Mileometer looks to be flashing up the normal distance then going a little crazy flashing up all sorts of nonsense.
Cheers
Phil
A3RUO, a few bolts and we're done
Posts: 378 |
Hi Phil It seems that the tyre monitoring system is not very accurate and mine failed after it had done 5k miles. I never relied on it. Same thing happened on my mileometer. It went away and luckily never appeared again. regards
15 Weissman GT5 11 Aero8 SS 21 Q7 23 RR 24 Def'r 130 1960 XK150 DHC 1970 E-type 2024 Huracan Tech
Posts: 20 |
Thanks for your feedback. I'm okay with inaccurate but of course when it alarms that's annoying isn't it.
My hope is that I can sort of get these working for completeness sake as opposed to relying on them as being accurate in ant way.
Thanks
Phil
Posts: 961 |
I know they're not 'integrated' as such but I have seen some very impressive wireless tyre pressure monitoring systems from a company called Tyrepal: http://www.tyrepal.co.uk/I don't think I've ever seen a report about manufacturer TPMS that don't throw up false readings/warnings!
