Posts837,997
Posts: 488 |
[quote=PaulV]Still a belt drive there, but no idea what the rest of the gubbins does! [quote=Obie]How about this concept from Garage 56
Looks like the drive train from the EV3
Oh I didn’t know, Its on the Garage 56 Facebook page, I know they do EV stuff so assumed it was theirs. Just spotted the link to Potenza Technology. http://ptech.co/?fbclid=IwAR2yIBgxdZepTAbZ7i36yPd9JdGW4LDrZzwsTFVv7tiNPoGtu3FIFtgXaL8#Top
Posts: 365 |
The question is where do you get an aluminum core? I would like some weight loss.
2017 M3W Sport Green
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
What year did they switch away from aluminum to steel or is it the other way around?
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
The question is where do you get an aluminum core? I would like some weight loss. You send off your aluminum sprocket to whoever is doing the Supermax conversion, they convert and send back.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
The steel rear sprocket replaced the anodised alloy in early 2015. The alloy sprockets only had a life of about 3 - 6,000 miles, although the kevlar drive belts seem to last for ever.
Posts: 159 Likes: 1
Posts: 159 Likes: 1 |
From Morgan Spares here in the States
I can get a steel sprocket and I'll look up the price but really a much better alternative is our poly coated aluminum sprocket, $525. Still nice and light, quiets down the noise immensly and just has great durability all of the way around. Motorcycle folks been doing this for years. We have several folks who have done this upgrade and can speak to the improvement. I would need your old one back in exchange. It is pictured on our 3 wheeler accessory page.
Let me know, I can quote steel one on Monday if you still decide to go that route.
Regards Linda
I told her I'd probably go with the poly coated one. I'll order it on Monday.
Dutch Junge 194 Mound St Logan, OH USA 43138
2012 3 Wheeler 1980 + 8
Posts: 1,947 |
The steel rear sprocket replaced the anodised alloy in early 2015. The alloy sprockets only had a life of about 3 - 6,000 miles, although the kevlar drive belts seem to last for ever. Mine was changed to steel at 6400 miles. The aluminium one used to lead to masses of black dust in the cockpit even though I had done my best to seal gaps behind the seats. Not so with steel one.
Posts: 213 |
I finally decided on the steel one to be done with it. After 8000 miles I estimate my alloy sprocket was 40% - 50% gone. I think there is at least one poly failure mentioned on this site. BTW, my bevel box has quieted considerably after 8000 miles.
Inge
Posts: 159 Likes: 1
The motorcycle shop I've been talking to asked me how tight the belt was and what was the deflection. Don't know about the rest of you but my belt doesn't deflect at all. It's really tight. I'm wondering if that contributes to the aluminum sprocket wear ?
He said that the typical deflection on a motorcycle belt is 5/8" He's got a gauge that uses a weight to check that.
