1 members (Montegue), 289 guests, and 53 robots.
+8Rich 93
Posts837,277
#643635 11/06/20 04:41 PM
Hello everyone and i hope all has been well with you all... smile
Has anyone swapped out their older rearward shifter location and went with the new stock Miata forward shifter location?
Early rearward mounting of the shifter.
Newer to current forward shifter location.
I may have a need for the rearward mounting assembly is someone has swapped out the old for the new.
Let me know.
Thanks and stay safe healthy ya'll... smile
Dan
Dan
Dan, looks impressive. What is the background to this?
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
Dan,
I have in fact done the conversion to a forward shifter and have the rearward adaptor as surplus. In very good condition I might add. It seems unnecessarily beefy and I don't really understand why MMC went this route when the forward mounting suits the M3W so much better.
Late 2012 M3W
Any chance of pics of this conversion please - I don't quite understand it!
1928 Superaero Jap 3 wheeler
2013 5 speeder 3 wheeler
The basic conversion is to simply remove the remote shifter housing and relocate the shifter forward, to the location used on the newer M3Ws. The photos Dan provided at the beginning of this thread show an early car gearbox with the remote shifter housing (first photo), with the lower photo showing a later one with the standard Mazda shifter mounting, which is about 7" further forward.
Parts wise, it requires obtaining a top shifter housing (available from Mazda dealers) and suitable modification of the gearbox cover. I found the original shift lever, being dead vertical, was unsatisfactory so modified it to be longer and "cranked" to my liking. I also took the opportunity to make a new gearbox cover that provides more legroom and a generally more open feeling in the cockpit. Here are some photos of the original and new gearbox cover, and the finished installation.
Late 2012 M3W
Very impressive.
Nicely done Steve👍
Really nice! thumbs
I also like the Little leather pocket just in front of the co-pilot. love I guess it's fixed with a couple of press studs, isn't it? Then you can unclip it and take it with you, right?
www.speedymarmots.com
The leather pocket is a typical motorcycle tool bag, most often seen fitted to the front forks below the headlamp of custom bikes. Press studs or velcro would be a better solution, but I simply used the single bolt fitting for which it was configured, with a thumbscrew so removal is fairly easy, though not super quick. I actually have not felt the need to remove it since it was installed a couple years ago. But then again I don't leave the machine unattended very often or for very long.
Late 2012 M3W
Here's a couple more pictures to possibly better explain the setup, early versus new.
Early:
New:
Dan
