Topics48,362
Posts813,324
Members9,215
Posts: 1,075 |
Hello everyone and i hope all has been well with you all...  Has anyone swapped out their older rearward shifter location and went with the new stock Miata forward shifter location? Early rearward mounting of the shifter. ![[Linked Image]](http://pic80.picturetrail.com/VOL846/863774/24797881/413763365.jpg) Newer to current forward shifter location. ![[Linked Image]](http://pic80.picturetrail.com/VOL846/863774/24797881/413763363.jpg) I may have a need for the rearward mounting assembly is someone has swapped out the old for the new. Let me know. Thanks and stay safe healthy ya'll...  Dan
Dan
Posts: 975 Likes: 20
Posts: 975 Likes: 20 |
Dan, looks impressive. What is the background to this?
2025 Plus Six - 1909 2009 Roadster 1983 4/4 4str Board member Morgan Sports Car Club Holland ('21)
Posts: 759 Likes: 23
Posts: 759 Likes: 23 |
Dan,
I have in fact done the conversion to a forward shifter and have the rearward adaptor as surplus. In very good condition I might add. It seems unnecessarily beefy and I don't really understand why MMC went this route when the forward mounting suits the M3W so much better.
Steve Late 2012 M3W
Posts: 79 |
Any chance of pics of this conversion please - I don't quite understand it!
1928 Superaero Jap 3 wheeler 2013 5 speeder 3 wheeler
The basic conversion is to simply remove the remote shifter housing and relocate the shifter forward, to the location used on the newer M3Ws. The photos Dan provided at the beginning of this thread show an early car gearbox with the remote shifter housing (first photo), with the lower photo showing a later one with the standard Mazda shifter mounting, which is about 7" further forward. Parts wise, it requires obtaining a top shifter housing (available from Mazda dealers) and suitable modification of the gearbox cover. I found the original shift lever, being dead vertical, was unsatisfactory so modified it to be longer and "cranked" to my liking. I also took the opportunity to make a new gearbox cover that provides more legroom and a generally more open feeling in the cockpit. Here are some photos of the original and new gearbox cover, and the finished installation. ![[Linked Image]](https://www.tm-img.com/images/2020/02/27/IMG_0193.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/02/27/IMG_0194.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/06/12/IMG_0285.jpg)
Steve Late 2012 M3W
Posts: 26,759 Likes: 424
Posts: 26,759 Likes: 424 |
Posts: 3,854 Likes: 2
Posts: 3,854 Likes: 2 |
Posts: 945 Likes: 16
Posts: 945 Likes: 16 |
Really nice!  I also like the Little leather pocket just in front of the co-pilot.  I guess it's fixed with a couple of press studs, isn't it? Then you can unclip it and take it with you, right?
The leather pocket is a typical motorcycle tool bag, most often seen fitted to the front forks below the headlamp of custom bikes. Press studs or velcro would be a better solution, but I simply used the single bolt fitting for which it was configured, with a thumbscrew so removal is fairly easy, though not super quick. I actually have not felt the need to remove it since it was installed a couple years ago. But then again I don't leave the machine unattended very often or for very long.
Steve Late 2012 M3W
Posts: 1,075 |
Here's a couple more pictures to possibly better explain the setup, early versus new. Early: ![[Linked Image]](http://pic80.picturetrail.com/VOL846/863774/24797881/414440849.jpg) New: ![[Linked Image]](http://pic80.picturetrail.com/VOL846/863774/24797881/414440847.jpg) ![[Linked Image]](http://pic80.picturetrail.com/VOL846/863774/24797881/414440848.jpg)
Dan
