5 members (SEG, B3MOG, Chris Cosher, Image, nick w), 282 guests, and 27 robots.
+8Rich 96
Luddite 52
Topics49,904
Posts838,079
Page 4 of 4 1 2 3 4
Gosh, I bet they squeak a bit! Obviously a dire lack of rear end maintenance. Before anything else, I would give everything a clean up, lubricate the springs along their length where accessible with motor cycle chain oil spray, check spring shackles and pins are free to move and make sure that shockers are not seized. Then give the rear end a good few pushes up and down to see if it settles any lower. Lowering blocks may still be worth considering if no improvement. I have no direct experience of a 4/4 but it does not look right somehow.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
It isn't as bad as it looks (only a little squeaky) although a clean is in order. It also seems to work ok.
I think I will be going with the Axle centralising kit & lowering block from mulfab
2009 Morgan 4/4 Sport
A good greasing works wonders for the springs.
Motorbike chain lube is great for spraying into the hard to reach bits
Especially if you choose the type for ‘O’ ring motorcycle chains as it does not attack the rubbers in the spring shackle bushes! Some spray chainsaw lubes that I have seen used do, just a word of caution. The correct lube doesn’t cost more.
BR
Colin
BR Colin
BR
Colin
Good point Colin thumbs
Yep I use motorbike chain lube
+1. Castrol Chainwax is excellent
Bud
4/4 "Stanley"
And a can last forever.
Thank you for all your recommendations and help guys! Some rear-springs TLC is in order soon!
Page 4 of 4 1 2 3 4
