Hi Steve
That new tunnel cover looks very good. Did you do it yourself?
Could be a winter project?
Nigel
Nigel,
Yes, fabbed the cover from fiberglass. Carved/sanded the form out of styrofoam, covered that with 'glass and epoxy resin (doesn't dissolve the styrofoam) and sanded to shape to make a male buck, then waxed it well and laid polyester resin and 'glass over that to make the part. I was trying to be lazy and not bother with a female mold, but as it turned out the amount of finish work doing it the way I did was vastly greater than if I had gone ahead with the mold.
Here's a photo of the buck, after the part was pulled off of it. The pink is filler, used to help finalize the shape.
![[Linked Image]](https://www.tm-img.com/images/2020/06/13/IMG_0200.jpg)
