0 members (),
181
96
Topics49,860
Posts837,485
Posts: 5,465 Likes: 171
Posts: 5,465 Likes: 171 |
I hope I am wrong but I vaguely remember hearing that there is a potential fault with hazard lights that can cause one of the control modules to fail. I do hope this is duff information as these are expensive and hard to get.
Posts: 37,416 Likes: 977
Posts: 37,416 Likes: 977 |
I recall reading that someone had a short on an indicator light fitting which took the dash control panel out, not wanting to concern you just to make you aware.
Posts: 27,810 Likes: 749
Posts: 27,810 Likes: 749 |
Yes on some cars Richard it does that.
Posts: 149 |
Spent the last two or three hours loosening the steering column and removing the dash from its fixings. I cannot find anything wrong, nor can I find any relays for the hazard lights. There is a large box marked Morgan Dashboard Control and a smaller black box with no markings. I cannot find either on the schematic indeed there are many differences from the wiring diagrams. I will look at some more from the GoMoG site although the one I have should cover my vehicle. Mine's 2001 and the schematic was for 1998-2004.
Anyone got any more ideas?
Perhaps I ought to find an auto electrician or should I go to a Ford dealer? I'm not sure it is all Ford wiring apart from the engine stuff. The dashboard wiring is the same as for a +8 of similar age. Don't be shy about employing an auto electrician, he'll crack it in minutes if he's good. I get king pins changed by an expert as although I do servicing and brake rebuilds I'm not equipped to do them so leave it to the experts. There was a French owner that followed the instructions religiously provided on here for king pin replacement and ended up being hospitalised with a broken jaw and losing some teeth, so the message is recognise your own limitations. Good luck. Thanks for that. I've put it all back together but finding an auto electrician is another matter. I have an appointment for 1st July! Still I have other things I can get on with gardening, sailing, restoring an old dinghy, tidying the garage (a career job) and many other things. I won't be idle. I fitted LED indicator and brake lights from BCL. Went round in circles trying to get them to work. One circuit would work and not the other. Eventually gave up and arranged for them to be fitted by an auto electrician via RTCC. He like me had problems, spoke directly to BCL and fitted different resistors which sorted out the indicators. However was unable to get the brake lights to work if the indicators were on. He eventually gave up. The cost for his time in not getting them to work, cost me a small fortune.
Posts: 50 |
Have no idea if this might help... a pic of the relays behind the dash on my 1986 +8 Ignore the blue relay which controls auto choke operation, the other two are flasher related and you can perhaps gain understanding by checking the colours of the wires and identifying them from the colour code list in the link below... Perhaps a handy sheet to print out ..? http://www.mgb-stuff.org.uk/colourcodes.htmGood luck. ![[Linked Image]](https://www.tm-img.com/images/2020/06/17/1985-8-behind-dash-relays.jpg) Hi Luddite. My flasher relay (as well as relays for fuel pump, fuel injector and cooling fan) are all in the fuse box under the bonnet. The colour code legend will be most useful. I will print that off and have a look at that tonight. Many thanks Richard
Richard Edwards rme877@gmail.com
Posts: 50 |
Perhaps I ought to find an auto electrician or should I go to a Ford dealer? I'm not sure it is all Ford wiring apart from the engine stuff. The dashboard wiring is the same as for a +8 of similar age. Don't be shy about employing an auto electrician, he'll crack it in minutes if he's good. I get king pins changed by an expert as although I do servicing and brake rebuilds I'm not equipped to do them so leave it to the experts. There was a French owner that followed the instructions religiously provided on here for king pin replacement and ended up being hospitalised with a broken jaw and losing some teeth, so the message is recognise your own limitations. Good luck. Thanks for that. I've put it all back together but finding an auto electrician is another matter. I have an appointment for 1st July! Still I have other things I can get on with gardening, sailing, restoring an old dinghy, tidying the garage (a career job) and many other things. I won't be idle. I fitted LED indicator and brake lights from BCL. Went round in circles trying to get them to work. One circuit would work and not the other. Eventually gave up and arranged for them to be fitted by an auto electrician via RTCC. He like me had problems, spoke directly to BCL and fitted different resistors which sorted out the indicators. However was unable to get the brake lights to work if the indicators were on. He eventually gave up. The cost for his time in not getting them to work, cost me a small fortune. Please don't mention words like "small fortune". That frightens me! Who/what are RTCC?
Posts: 50 |
I recall reading that someone had a short on an indicator light fitting which took the dash control panel out, not wanting to concern you just to make you aware. After supper I will look at exposed wires as they enter the light fittings etc in case there is a short. The dash control panel sounds like an expensive bit of kit and that's before trying to fit it. This gets scarier by the minute.
Posts: 50 |
Yes on some cars Richard it does that. After supper I will look at the wires as they enter the light fittings and pray I find an easy solution.
Posts: 50 |
I hope I am wrong but I vaguely remember hearing that there is a potential fault with hazard lights that can cause one of the control modules to fail. I do hope this is duff information as these are expensive and hard to get. Hi, By one of the control modules I assume you mean one of the two black boxes under the dash. Will the factory have them? At least they would tell me where I could get one, if necessary.
Posts: 8,671 Likes: 408
Posts: 8,671 Likes: 408 |
and what looks like a couple of external diodes? Hi, Deejay. I'm no electrician. The diodes, if that's what they are, are soldered across two pins in the hazard switch. Perhaps later I will take it apart and post a photo but we're going sailing shortly so I will be away for a few hours. The diodes are there to isolate paths to both left and right indicators when hazard function is selected and they work together. Obviously they need to be separate for indicator function. FWIW I believe the second hazard relay on the GoMog dash diagram is to isolate indicator selection when hazards functioning.
