6 members (Winigo, Ncik P, Pittsartist, Clipper, hillclimber, AndyGoff), 301 guests, and 52 robots.
+8Rich 81
Topics49,859
Posts837,505
Jonny72
#645515 19/06/20 06:41 PM
Scottsi Offline OP
Can anyone give me fuse layouts for the under dash and under bonnet locations on a 2007 4/4 with a 1.8 Ford Duratec engine? Thanks!
Hi Scottsi
You can download a parts guide from... https://mogparts.net/parts-guide
Treat as a guide since some cars may have a slightly different configuration
Hope this helps
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
Easier to follow wiring diagrams can be downloaded here although they don't show specific fuse and relay locations.
This is from my 2006 car
The dash fuse box is under the dash above the tunnel.
I have posted a photo on your fb page showing the card from my 2008 4/4 (1800 Duratec)
I think it is exactly the same as the one John has just posted.
Pete
Hello,
New to the Forum.
I have a 1988 4/4 with a 21 Fuse horizontal layout, I have no cover and have no idea which Fuses do what.
No indicators and need some help.
To make it worse somehow a few connections came off the box, I could do with a pic of the Cover inside and the Fuse allocations.
Glenn
Here you go
fusebox
Superb John, is there a key to the Fuse rating too??
I did find a blown 10Amp in the mid top row, this brought back my Headlights, this I thought was strange as I understood that traditionally Headlights were non Fused?
I still have no Indicators or Hazards though, is the Flasher Unit the modern plastic cased jobbie hanging down in front of the Fuse box or is this something different?
It appears to have the normal 3-Pin connections I would be expecting.
If you scroll down the later versions have ratings. I don't imagine they will be different.
I would also check the earthing points. GoMog lists locations but probably the one on the drivers side wing will be corroded.
The flasher on my 90s cars was a modern black box just hanging in space of the loom.
