7 members (BLUE+4, John Wilcox, Ncik P, aerotaff, Ritchie B, Alistair, TeddyAds), 349 guests, and 93 robots.
+8Rich 86
Topics49,851
Posts837,443
E
exbiker Offline OP
E
Anyone having running problems with series 2 roadster - sometimes when stationary revs stay at 2000, stays there for quite a while, sometimes requiring the engine to be re started before it rectifies itself, sometimes after a few minutes it clears itself, this is not like the revs hang whilst driving, although it does that as well and I have been told that is a charicteristic of this engine, any info appreciated, Cheers
2017 Mercedes Benz SLC 200 AMG.
2019 Mercedes Benz GLA 200 AMG
Now Ex-Mogger!
My 97 +4 did that and it turned out to be a duff ECU.
It could be I guess an air leak after the throttle body.
E
exbiker Offline OP
E
Cheers for that, am looking into trying another ecu from local dealer, never does it for the dealer though!!
Now Ex-Mogger!
Ditto. It took 3 visits & 2 years to fix mine
Smile, it confuses them
Online Sad
next time it does it - whip out your trusty iPhone and video it occuring. I find it makes you look a lot less barking trying to explain it when you can show the video.
Better still if you happen to be driving then get the better half to use theirs so you still drive......
JJW Offline
Hi exbiker,
Has the dealer looked at the Idle Air Control Valve? If it is not the ECU, it might be a sticky IACV? Should be easy to check. You find it on top of the inlet at the throttle body. It looks like this (upside down)
The ECU controls idle by controling this valve allowing air from the upstream port to the downstream port in a channel that by-passes the main trottle valve. Good luck with it. Cheers J (also exbiker) thumbs
E
exbiker Offline OP
E
Thanks for all the information everyone!!
Got plenty to do now, amazing how you get new ideas from other people, never even thought about videoing the event!!
Will be in the dealers during the next couple of weeks so will let you know the outcome, Thanks
Now Ex-Mogger!
E
exbiker Offline OP
E
It's taken a while but I think I have sorted out the problem.
The air inlet pipe to the air cleaner has a rubber end, (both ends, but it was the open end causing the problem) the rubber had folded into the inlet pipe thus restricting the airflow, so far none of the high revs at idle (the revs still hang under accelaration but have been told by loads of people this is normal for the engine in this model)
Now Ex-Mogger!
JJW Offline
Do you mean the ribbed hose that takes the air from the area above the radiator to the airbox intake? I have seen this hose folded inward a bit at the radiator on several roadsters. One of my future projects will be to replace it with something smoother and possibly to a cooler area. But if it is this hose you talk about I am amazed that it caused a high iddle. thinking At iddle there is soo litle air required, a slight restriction in the intake should not make a difference.
I know what you mean with the rev-hang at high rpm, anoying, but as you say many engines of many brands do this. evil Its caused by the pollution control gizmo's (EGR/IACV).
Cheers J
