2 members (Barkbark, +8Rich), 289 guests, and 94 robots.
+8Rich 76
Topics49,869
Posts837,666
Moggo
Originally Posted by Mark666
HI Guys,
Only had my 2015 Plus 4 for a few months and never heard of this "Inertia Switch". My handbook says it's a Red Exclamation Mark and is only fitted to a Plus 8, so no help there.
Is it something fitted to older models of the Plus 4?
Regards
Mark
I understand it to have been a legal requirement for a great number of years it's to cut the fuel supply in the event of an impact to cease fuelling a possible fire situation. They are sited in my experience under the bonnet on the passenger side near the firewall and are around 2" square with two electrical connections and the front of the switch has a rubber covered reset button.
I have something fitting the description, see pic.
Learned something today, Thanks
Mark
2015 +4 Ferrari Le Mans Blue
Well spotted thumbs
Here is a diagram covering my Plus 8 but I notice your car has the same colour coding.
Yes it should be on the bulk head by passenger side above the wiper motor.
In this photo where I am siphoning the header tank to change out the plastic t piece for a SiFab metal one it is the black square behind the hose as it enters the tank
On my 94 plus 4 it’s day glow orange. First thing that visually hits you When you open the bonnet
Tony
1994 Connaught Green Plus 4
Just noticed your belt guard, my late 2004 S1 never had one fitted
Well mine had no air filter from new. Obviously MMC rationing parts
laugh2
It is not much of a guard. In a factory it wouldn't pass the regs but it is better than nothing.
laugh2
Mine had the big GRP air scoop completely missing
Originally Posted by +8Rich
Originally Posted by Treesurveyor
Its very useful if you need to prime your oil pump in the event of sudden oil loss. The AA man tapped it with a spanner to activate so the engine turns over without firing; useful tip maybe🤔
Thanks for that Treesurveyor I'll use that at next Lub oil change thumbs A lot easier than removing the rotor arm.
I'm glad you had your leakage now laugh2
I'm not paranoid about it, but have discovered that trying to chalkpaint the sump plug results in the mark slipping (Not sticking on the sump body) , so find myself constantly on my knees checking for weepage pantsdown innocent
06 Saab 93
I understand that, I put a smear of Blue Hylomar on the plug threads. Gearbox and diff as well.
