7 members (Taffmog, BigLes, itsfrank666, waikiore, TomS, High Hamster, mph),
334
41
New
Topics48,365
Posts813,352
Members9,215
Posts: 584 Likes: 21
Posts: 584 Likes: 21 |
Just fitted mine today, thanks to all the previous contributors/threads for the very useful tips and pictures. 👍 Also swapped out the OE airfilter and snorkel, with a view to doing something different. ![[Linked Image]](https://www.tm-img.com/images/2020/06/28/20200624_212802.th.jpg)
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
Posts: 895 |
Good work! Have you noticed a difference after fitting the brake reaction bars?
Rob
4/4 Sport Grey
Posts: 501 Likes: 2
Posts: 501 Likes: 2 |
Permit me to toss in my impressions after fitting BRS. I did not expect much change, if any at all. I am a "cruiser", so not much hard braking. Fitting BRS was an experiment, so cheap that it would not be much of a loss if they did not have any effect - I'd had some fun fitting them anyway. However, I did notice a difference. I cannot say regarding the hard braking - as I do not brake hard that much.But the whole front of the car calmed down, in a way difficult to describe. It felt more stable, not moving around that much both horizontally and vertically (which I can't explain, but anyway - less "nodding dog"). It felt slightly closer to driving an ordinary car - in a good way. I admit that there might be a bit of placebo in this, and the changes were quite subtle. The only way I can explain this is that the BRS stiffens the whole front of the car, reducing the inherent flexing. And not only during braking, but most of the time, as I suspect there are constant micro-movements. Something that is needed? No, the earth did not move beneath my feet? Something I would recommend? Yes, for sure. A relativly small improvement, but cheap and easy to do. Next is the Panhard rod, lying on the garage floor ready to go in...
Robbie the Norseman 2004 V6 Roadster Sherwood green
Posts: 26,761 Likes: 425
Posts: 26,761 Likes: 425 |
Robbie, I would agree it adds stiffness. You described it perfectly. You will notice the panhard rod much more. The anti tramp is maybe a bit over the top but but on very fast acceleration it helps. John
Posts: 697 Likes: 7
Posts: 697 Likes: 7 |
Do you have both of them fitted to you Roadster John?
Posts: 895 |
Thanks Robbie
I need to fit one. Like you say inexpensive and nothing to loose.
Rob
Rob
4/4 Sport Grey
Yes RobCol, and well put Robbie, I would have said the same, but less well so. Just shy of 6 months ownership/driving, and 10,000 miles on, I do get a bit spirited at times, and I can attest to a marked difference in cornering hard whilst braking, and less skittishness up front when coming out. Would like to have done it sooner, still, many more (s)miles to go! Like you, I am waiting for the opportunity to fit the PR; sadly no garage so fine weather, and less fatigue need to be convergent! Antitramp bars are later, then I can get at the springs and hunt down the squeaky passengers 🤣
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
I was not expecting to notice much difference after fitting a Panhard rod to my Roadster, but the improvement in stability under hard acceleration is significant.
Posts: 1,384 Likes: 56
Posts: 1,384 Likes: 56 |
hmmm, been thinking about fitting the brake reaction bars perhaps I should consider the Panhard rod too. Only experience of the Panhard was fitting one to an MGB roadster that I converted to V8 back in the late 90's. Made a huge improvement.
Do you have both of them fitted to you Roadster John? Gary if you mean anti tramp bars just one on the drivers side.
