0 members (), 298 guests, and 38 robots.
John V6 69
+8Rich 66
DaveW 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Topics48,345
Posts813,037
Captain Morgan, IRWIN
Page 5 of 14 1 2 3 4 5 6 7 13 14
I'm on my 5th Mog, I've driven a Plus6 for about an hour on test, just didn't bond with it and decided to stick with my Roadster
Originally Posted by pete757
Originally Posted by Budster
What I find more worrying is the inability for them to be economically repaired, once the chassis tub is damaged.
However, I imagine that a number of modern cars would have a similar issue?
Bud
4/4 - Stanley
As my JLR engineer son observed when he had a good look at the 'CX' platform,, there is NO deformable 'crash structure' up front. So any frontal biased impact is transferred to the chassis... deformation etc.
NO idea WHY it was designed like this... Lotus have used a deformable crash structure on the front area of the Elise 'tub' since it's inception in 1996... and the newer Evora launched in 2010 also has one... additionally the chassis is made up of 3 segments that can be separated and replaced to repair crash damage, mitigating the 'write off' scenario.
I am sure the insurance industry will begin to see this and I fear all CX platform cars will have elevated insurance premiums as a result...
Not too sure about that statement Pete?
All new cars will have been "crashed tested" extensively....the very last thing you want is transferable energy into the cabin?
The damaged ones I have seen, seem to have "crush cells"?
2004 Roadster S1 3.0 V6 gone!
Mark
A mate once had a Corvette with a sticker in the rear window which read:
“Speed kills, live longer, buy a Porsche”
Wondering if these might soon be available on the options list of the Plus Six?
hide
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
Originally Posted by Peter J
The car needs better suspension, I hope someone is working on it.
AFAIK yours and my pal in South Gloucestershire smile
'09 Gen2 MINI Cooper ragtop
I never felt in total control test driving in the plus six. It feels like an untamed beast. The plus four feels just right but I expect you could easily loose it.
2025 MG ZS EV aka Trigger
hide
My other car is a...oh on a rack in a scrap yard grin2
Looks to me like The Plus Four has replaced the Plus 4, Roadster and made the Plus Six almost redundant in one fell swoop.
Rob
4/4 Sport Grey
Smile, it confuses them
There will always be some nutter who thinks way more power is better. Oh hang on that's me, whoops.
Agreed, but it lacks character vs the trad , no more lost teeth. I wish MMC every success with it.
It is my understanding, after talking to a number of experienced drivers, that perversely, the car is safer in Sport and Sport Plus mode.
How is this?
Consider this situation. You have been driving along at about 60 to 65 on a single carriageway road. There is a slow car in front of you, you slow to 30 or so, waiting for an overtaking opportunity. The car thinks you are in traffic and puts you in the highest gear possible, keeping the revis at about 1500, for maximum torque and maximum fuel efficiency. You see a possibility and push down the loud pedal. There is no turbo lag, peak torque is from 1250 rpm. what seems to be turbo lag is computer lag as the engine and box work out that no you are not in traffic and want to go. So the box drops suddenly to 2nd or 3rd and with an open throttle and massive torque the car squats down on the bump stops, the suspension cannot cope and traction is broken: all power goes to one or other wheel. At that point you are a passenger as there is no traction control to help you.
Replay the same situation, but the box in in Sport +. This time when you slow the box holds a relatively low gear, because its program says "this boy is being sporty, so he may well need power soon". The engine is now at 3500+ rpm. You see the opportunity, push the loud pedal and there is no down change, the car surges forward on a wave of torque, without squatting on the rear bump stops and all is well.
The car needs to have power seriously limited when in normal Drive mode. I hope someone is working on it.
With the sort of suspension improvements SSL has brought to trads and now S4 Aeros the car would be rather nice, but always able to bite.
With a revised relationship between gearbox and engine management systems it could be fantastic.
FWIW I also agree with your thinking Peter, although possible not use of the Sport + button which amplifies throttle pedal sensitivity. In the days of early three speed auto transmissions the kickdown took considerable "thought" presumably as hydraulic pressures were built up and sent to the clutch bands. The effect, when it eventually happened, was a somewhat crude lurch forward with the dramatic reduction of engine to rear drive ratio. I remember a brief yelp from the skinny(ish) cross plies on my CV8 when the TorqueFlite gearbox kicked down to second and an even bigger one if you could persuade it to kickdown to first. The 460 lb-ft of torque from the Chrysler 383 were diluted by the delayed change, softish torque converter and sheer weight though.
Given nearly half a ton less, turbo torque on demand and dramatically quick changes of the Plus Six's fantastic ZF 8HP box its not difficult to see what it would be like on a slippery road to the unaware. Lack of LSD might help in the dry, spinning away excess power but things could go badly wrong in the wet before that could happen. To me there is something inherently wrong in deliberately not spec'ing an LSD on a car with this weight and power delivery to offset lack of traction control.
