8 members (hillclimber, JohnHarris, jbk, TalkMorgan, mph, +8Rich, B3MOG, tezzer),
378
84
Topics49,848
Posts837,405
Posts: 295 Likes: 5
Posts: 295 Likes: 5 |
Karen at Moto-Lita has kindly offered to send me the plastic job until mine is sorted out.
Seems to me that it would be a simple matter to machine a shallow annular groove at the appropriate depth in every wheel boss. Then the rubber "o" ring would locate with that, and the problem would be sorted. But then if they don't acknowledge that there is a problem ...
Nick Connaught Green Roadster S3 V6
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
I have a Motolita with just an insert that used to drop out until 2 very small drops of Bostik cured the fault the lip on the insert was too small for tape. The glue spots are in line with the Morgan wingtips for ref should the insert need lifting out. Bloody nuisance when driving!
Posts: 3,480 Likes: 42
Posts: 3,480 Likes: 42 |
Vincentvg, very much the former -- we even describe one of our local bits as an "African Road" some of the guys over here use it to decide on the best setting for adjustable shocks!!!!!!!
Cheers!
Posts: 28,896 Likes: 352
Posts: 28,896 Likes: 352 |
Robbie, Sounds like you need one of those Africar thingies. Slight Mog association, as they're made of wood  Cheers,
Posts: 1,245 Likes: 2
Posts: 1,245 Likes: 2 |
I had the same problem and used the insulating tape "fix". In an added twist, on my first timed run at Forrestburn hillclimb a couple of weeks ago, the matching Morgan tax disc holder unscrewed itself and flew across the car, ending under my feet. At the time, I was in the middle of a series of adverse camber "esses" .......interesting!
Posts: 367 Likes: 1
Posts: 367 Likes: 1 |
I had the same problem just last week while negotiating some fairly bumpy roads on Tiree. Never had the problem on the last car, but that did loose the front wing stay bolts both sides and three radiator mounting bolts after a few days in Belgium
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
I lost a front wing stay bolt early on. Need to check regularly!
Keep promising myself a visit to a Forrestburn meeting, but they frequently clash with other events I'm involved with.
Looks like it will have to be next year now...
Cheers,
