5 members (britmog, Image, MartinB60, sprinty, Soleng), 280 guests, and 46 robots.
+8Rich 90
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,340
Christoph
Page 6 of 7 1 2 3 4 5 6 7
Very smart.
The functioning "prototype".
Still needs wood facia, dial bezels, glass and proper Speedo needles - the ones fitted are carved out of a piece of wooden cloths peg. I'm sure that committee would approve of the use of some wood smile
The lockdown has slowed down access to components and I have to wait until people get back to work in order to try and source the instrument spare parts to complete the clock.
The program that drives the microcontroller is pretty much complete. It has a small Real Time Clock with a button cell battery to keep the time so that the clock hands automatically reset to the correct time at power up. It also automatically compensates for daylight savings time and advances and retards the hour on the appropriate dates and times.
The next trick is to try to port it to a smaller microcontroller and try to power it with a rechargeable lithium battery. I suspect the current draw will be too much to effectively power it with a small battery pack.
Well done that man!
If you only wake up the microcontroller every minute and have stepper motors that maintain their position when unpowered then a battery pack is doable. I used to work for a company that designed and made equipment for the visually impaired and designed a lot of low power, long battery life products including watches. There was always a hunt to push down the current draw by a few micro-amps here and there. Good luck with completing the project. Wood is allowed .......just as long as it's Ash!
Finally got round to finishing my bonnet vent off. I coated it with the Easy composites XCR skinning resin then sanded and polished. It's come out a lot better. Fitted it OK but might change the fasteners for countersunk screws. When the rad fans are on some air is coming out so it will be doing some good.
On to the next project now as I hope to be picking up, a new to me, +4 next week so I'll have to get rid of that horrid alloy gear knob.
Cheers
That does look good.
John07, what take your fancy in the knobs line?
Hawki,
Probably round and made from wood. Like the one I made for my last +4. But I've got side tracked into making a ball turning attachment first. I should say I just hate working with wood, it splits and you cannot weld it.LoL.
Here's the one I made for my car with a MT75 gear box, the new car has a Mazda box so the fixing is different.
Cheers
John07 #647331 29/06/20 09:56 AM
John, Very impressive it looks very nice indeed. You could set up a business producing them if you didn’t hate working with wood.
I copied the Richbrook knob used on the Morgan Mazda gearbox. It has a metal insert which is threaded to take the original ring that covers the retaining grubscrews. I used the insert from the Richbrook for the gear pattern.
Peter, is that Burr Elm ? It's lovely grain
Yes it is Elm. It matches the new (ish) custom dash and re-finished Motolita steering wheel.
