6 members (RedThree, DaveW, mph, brownbaker, Rex_tulips, Bishmog), 705 guests, and 42 robots.
Adam12 71
+8Rich 69
John V6 51
9,215 Registered Users
V Twin 3 wheeler insight vid
by Luddite - 03/08/25 01:31 PM
Latest toy…
by Grumpy2 - 03/08/25 08:06 AM
Folding Reclining Seat Knob
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
Morgan plus Four 2025
by Jérôme, August 2
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
Topics48,379
Posts813,563
Members9,215
#650584 14/07/20 05:26 PM
One question: If you turn left or right at an intersection, does your turn signal also remain permanently on and must be reset manually? Mine stays on until I turn it off.
Best regards
Bernd
Added: It's a 1981 4/4 4 Siter with original indicator (it think)
Morgan 4/4, 4 Sider RHD, Build 1981
Mc Black #650585 14/07/20 05:27 PM
With the standard switchgear, it should self cancel if you have turned sufficiently (for example a 90 degree turn should be plenty).
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
Mc Black #650609 14/07/20 07:04 PM
Bernt
Can you tell us the year and model of your Morgan as it would help answer your query
Arwyn
Mc Black #650610 14/07/20 07:08 PM
TBM Online Content
Best regards
Bernd
My '72 resets itself, so I imagine your '81 will. However, as Paul says, it is dependant on 'amount' of wheel movement.
Is it a standard indicator stalk?
Mc Black #650613 14/07/20 07:24 PM
When living in Texas, I learned that using indicators, is considered a sign of weakness.
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
Mc Black #650614 14/07/20 07:29 PM
TBM Online Content
I love my indicators so much I used to leave them on.......self cancelling can be a little sporadic if there's not a full turn of the wheel.
Now fitted a little gizmo that starts beeping after a while if I've left them on smile
Mc Black #650643 14/07/20 10:05 PM
There should be a little egg shaped alloy cam on the top of steering column immediately behind the steering wheel hub.
It is this cam contacting the ears on the indicator switch which causes the indicators to cancel.
Not sure if the cam came fitted to the upper steering column when Morgan sourced it or whether it was done in the factory. Its pretty crude so probably it is a factory part.
Now this cam is drilled and tapped to take a small grub screw - probably something like No8 or No10 UNC.
What happens us that the screw slackens or drops out, and the cam remains stationary whilst the steering column turns which means the signals aren't cancelled!
Kind regards
Arwyn
Thanks Arwyn for the info.
Bernd
Mc Black #651603 20/07/20 05:22 PM
X
X
Hello, when I'm right in the 1970/1980ies Morgan uses the usual british stuff, as Triumph, Austin, Jaguar, Mini and so on.
It was high-tech. My Mini was selfchanceling, my Mums Volkswagen not...
As bespoke there must be a nose at the boss that switches the indicatorstalks.
If you undo the boss you see the cuts in the mechanism. And you see the noses.
In cause there are some years after the build, may be the mechanismn is worn ( you can test it with the boss off) or there is no nose at the boss. That you will see too.
That is the switch. May be you've got the sharp edged model. When you have a look at the center you see the two whole
for the reset.
https://allbrit.de/etk_detail.asp?Artikelnummer=BAU5345
Greets René
Hallo, wenn ich mich richtig erinnere wurden in den 70/80igern in den Morgans die üblichen Lenkstockschalter montiert,
die alle Engländer hatten. Die hatten den High-Tech Rücksteller, der Billig Polo meiner Mutter nicht.
Wie beschrieben müssen dazu in der Lenkradnabe ein oder zwei Nasen sein.
Nachdem das Auto ja etwas älter ist kann es sein das der Mechanismus kaputt ist (das kann man bei demontiertem Lenkrad testen) oder es fehlt die Nase an der Nabe. Das sieht man.
Oben im Link ist der Hebel. Vermutlch hast Du aber die älteren etwas eckigeren Hebel. Wenn man genau hinschaut sieht man
in der Mitte die zwei ausfräsungen in die die Nase eingreift.
Gruß aus der Landeshauptstadt
René
2018 plus4 (sports green)
Mc Black #651619 20/07/20 06:17 PM
X
X
Here you see it better:
http://www.minispares.com/product/Classic/Electrics/Switches,%20stalks/BAU5345.aspx?0912&ReturnUrl=/shop/classic/Electrics/Switches,~stalks.aspx%7CBack%20to%20shop
I think this part would fit if the mechanism is worn.
René
