Topics49,841
Posts837,325
Posts: 730 Likes: 58
Posts: 730 Likes: 58 |
Thinking of getting oils for the MOG. I'm looking at buying British oils and online I've seen a company called 'Westway Lubricants'. Has anyone used this company or indeed know of any other Companies that make oils in the UK.
Navy Dave 1976 Morgan 4/4
Posts: 697 Likes: 7
Posts: 697 Likes: 7 |
Morris used to make lots of oils for classics
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
They still do Morris Lubricants I believe the factory uses them.
Posts: 791 Likes: 143
Posts: 791 Likes: 143 |
Morris are based at Shrewsbury. 25 litre drums available delivered to your door 👍
Chris
2015 Plus 4 Silverlake Blue (2014 3.7 Roadster Crystal Blue) (2012 4/4 Sport Black)
Posts: 663 Likes: 14
Posts: 663 Likes: 14 |
I use Opie Oils. they are very knowledgeable.
Posts: 2,583 |
Millers Oils - based in Brighouse in God`s own county. They have a wide range of oils & other lubricants (Keep it clean!!!) - they do oils etc. for older and modern engines they also sell in smallish quantities. Their website is good for finding what is suitable for your car www.millersoils.co.ukThey will happily send you a brochure of products so that you can leaf through it in the privacy of your own home.
I use Opie Oils and they stock the full Millers range.
Posts: 537 Likes: 3
Posts: 537 Likes: 3 |
Bit of a tangent maybe, but came across this stove enamelled sign at Sheringham Station on the Norfolk Line a couple of years ago. Must admit to not knowing of Morris oils until then and have noticed a growing profile since. Not sure how old the sign is as it's condition seems too good to be original. ![[Linked Image]](https://www.tm-img.com/images/2020/07/18/Sheringham-Station_01.1261.LR.md.jpg)
Rob T 2017 Tungsten Plus 4
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
Use Morris's Servol, Golden Film and MLR castor based racing oils.
Can't fault them
Arwyn
Posts: 829 Likes: 22
Posts: 829 Likes: 22 |
I use Castrol Xl 20/50 on the +8. Oil change every 3k miles.
1980 +8 Blue And a few others ---------------- Stephen
