8 members (TBM, RichardV6, bmgermany, Mog on Island, Rex_tulips, mph, Sir Percival, Craig Jezz), 370 guests, and 40 robots.
+8Rich 65
Adam12 62
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,346
Members9,215
DWF #650388 13/07/20 08:00 PM
Interesting set up there. Pressure regulator too?
DWF #650391 13/07/20 08:15 PM
DWF Offline OP
Hi Bruce, thanks for your comments. Interesting whether the improvement is down to the K& N free flow filter or the cold air tube - probably both, but I wonder whether the length and routing of the convoluted tube is any less restrictive than the trumpet. I may try a half way house with a K & N inside the canister to replace the paper element if there is a noticeable loss of performance.
DWF #650403 13/07/20 09:18 PM
I can't answer scientifically your assumption regarding airflow through the tube but from observation of dust and grit collecting in the canister after driving through the desert then the airflow is considerable, I use a racing rain sock to keep the filter clean. The issue with the trumpet being in the engine compartment as well as restriction is hot air being drawn in.
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
DWF #651375 19/07/20 10:32 AM
Like Les , I cannot recommend going back to the original canister air filter system.
My results were not as spectacular as his, but the best I could do with the original system was 148 bhp , which rose to 186 bhp with the JR cone filter and Mark Adams chip.
I even tried replacing the filter element with a K&N part , but the difference was only minimal. The engine needs to breathe, what is OK for a low-revving 4x4 weighing upwards of 2000 kilos is not really suitable for a sports car weighing half that.
I am also not a big fan of the foam core type units (but the racers like them) , mine was a simple conversion using the existing brackets and rubber mounting of the cylinder. You need to keep the element clean, and re-oiled , so i just build that into my annual maintenance schedule. I have had mine for almost 18 years now and it still looks a fitting addition to the engine bay. Yes it would be better to ensure that it only took in cold air, but that involves a lot more thought, more truncking and something else filling an already crowded under bonnet area.
Andy G
1999 +8 , Indigo Blue.
DWF #651378 19/07/20 10:54 AM
I doubt that water coming into the air feed pipe would be a problem. When I had a ‘93 4/4 the intake was from the wheel arch via a flexi pipe that fitted over a steel pipe through the inner wing. It was about 18” above ground level so would need a deep water ford to be under water! I did have to replace and insulate the flexi though as even with the stock heat shield the exhaust manifold heat was melting it.
I have a nagging in the back of my mind to get a cold air feed for my Plus8 as tests have shown the air it sucks in gets quite hot. At least 20deg above ambient air. The surface of the stainless filter box with a K&N filter I have was measured at over 50deg C last time I tested, ambient was 15deg. Colder air would give a sharper response probably. I think the rule of thumb is +1bhp per 7deg lower temp. I fitted rear bonnet catch extenders to help get the hot air out but not done tests yet. I THINK they help as the rad fan doesn’t cut in quite as much, possibly due to easier air flow through the rad.
DWF #651382 19/07/20 11:01 AM
You don't need much water to destroy an engine. It doesn't compress. I tried a similar intake on my T16 +4 but decided the gain was minimal vs the risk
2025 MG ZS EV aka Trigger
DWF #651494 19/07/20 09:33 PM
DWF Offline OP
Hm, I'm ploughing a lonely furrow here! However I will plough on and report back with a subjective view when I have changed the filter. I do have to say though, torque rather than outright bhp is my thing.
DWF #651500 19/07/20 10:19 PM
I've done the same, ditched the stainless trumpet in favour of now a K&N, previously just a budget cone filter. Better breathing engine =better throttle response. I perceive increased torque, feels quicker\more grunt, and surprisingly better mpg. Getting the air from cooler area is next goal, as obviously its hot round the engine, but my pickup is in the same place roughly as the original paper element housing.
06 Saab 93
any info on the specific K&N, might give one a go but looking through their website I can't find a match for the plus 8
cheers
Gary
DWF #651523 20/07/20 09:38 AM
Swapped my SU's for a four barrel Edelbrock carburettor on my 1980 Plus 8. That allows for a nice big pancake chrome filter housing with a 10 inch K&N filter. Lots of clearance.
https://www.gooze.com/1501/1208-Ede...hzsPb6gIVmKztCh2x7wANEAQYASABEgK9X_D_BwE
