8 members (Robbie, Tweed19er, Morganmike, Themorganeer, tommog, Alistair, JohnHarris, Graham, G4FUJ),
225
76
Topics49,846
Posts837,383
Posts: 938 Likes: 19
Posts: 938 Likes: 19 |
There are so many spline variations that you must obtain the correct one to fit your vehicle.
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
There are so many spline variations that you must obtain the correct one to fit your vehicle. That's the point. If I look for "fitting a 2018 plus4" there I found no result. So my hope was: have a look at the FORD range (or something like this). René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Exactly right as Morgan used major manufactured components, so your vehicle maybe a Ford steering column you can cross reference. I’ve had my Nardi wheel on various cars over the years like TR’s, MG’s, Mini’s etc and I have adapted bosses to suit.
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
The proposed thread to catalogue the source of plus 4 parts would be useful if only it had been running for a while ..... if you knew who's parts bin Morgan robbed your steering column out of the job would be mostly done ..... there aren't any numbers on it anywhere that might be googleable to match it ? ..... measuring the spline diameter with a vernier and counting the splines might lead somewhere .
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
If you take off the existing boss & then measure the OD of the splines on the column, & count the number of splines these two bits of info will enable any decent boss supplier to match it up
