Topics49,880
Posts837,776
Posts: 9,550 Likes: 134
Posts: 9,550 Likes: 134 |
Grumpy, I will search my records for the one I bought. You could also measure your current paper one and search the K&N website for their similar sized one. When researching airflow I read Graham Bell’s book where he quotes tests on airflow and performance differences for different filters/ air supply enhancements. No HUGE improvements but cumulative benefits making up the differences he measured. Some interesting results.
Posts: 1,464 Likes: 99
Posts: 1,464 Likes: 99 |
Grumpy, I will search my records for the one I bought. You could also measure your current paper one and search the K&N website for their similar sized one. When researching airflow I read Graham Bell’s book where he quotes tests on airflow and performance differences for different filters/ air supply enhancements. No HUGE improvements but cumulative benefits making up the differences he measured. Some interesting results. Thanks for that. I’m thinking about replacing the entire canister so maybe I just need to measure the flange? Read about some possible fuelling issues? Runs lean?
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
Grumpy, I will search my records for the one I bought. You could also measure your current paper one and search the K&N website for their similar sized one. When researching airflow I read Graham Bell’s book where he quotes tests on airflow and performance differences for different filters/ air supply enhancements. No HUGE improvements but cumulative benefits making up the differences he measured. Some interesting results. Thanks for that. I’m thinking about replacing the entire canister so maybe I just need to measure the flange? Read about some possible fuelling issues? Runs lean? The K&N filter I currently use with my modified intake is F028e4 (came with different rubber flanges) The K&N filter I used in the original trumpet was A053a8 Hope that helps.
Posts: 19 |
OK, just to tidy up the loose end. I have now fitted the standard air cleaner box with a new Mann paper element and have done a few varying trips in the car. I have to say I have found no difference in everyday driving. This is not checking the performance on a rolling road or with a stopwatch, however with normal driving and some brisk acceleration subjectively I notice no difference. That said I rarely if ever accelerate hard with my foot flat on the floor, changing up through the gears at maximum revs! So for my laid back driving style no problem.
Posts: 203 Likes: 8
Posts: 203 Likes: 8 |
Andy
Bit of an old thread, but do you have a part number please for the JR filter? There’s no mention of Morgan on their website. Did you ditch the entire original filter housing?
Mike H Bourgogne Franche Comté
