7 members (JohnHarris, Whizjet, Wouter, B3MOG, bmgermany, John Winn, Graham, G4FUJ),
158
37
Topics49,901
Posts838,042
Posts: 14 |
Speedo & milometer not working but indicator lights still are.
Any ideas ? I needed a new speedo sensor 3 years ago - could that be favourite again ?
Many thanks
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Which model and year Richard?
Is the sensor on the gearbox output shaft or the offside front hub?
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
Aren't all on the front hub?
Besides a bad sensor, it could be a broken wire to the sensor (check the vulnerable area near the sensor) or in my case, I had a loose pin in the connector behind the electrics cover. So it's worth checking out the wiring before spending the money on a new sensor.
Steve Late 2012 M3W
For a while in the mid noughties Steve some cars had the sensor on the gearbox output shaft. My 2005 Roadster is this way.
On the hub sensor, there's a small built in light which flashes as the wheel turns, and this validates a signal, but you need dim lighting to see it.
OH! Just noticed this is in the three wheeler section! Doh!#
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
The wheel speed sensor also has an input to the ECU for engine idle control. There is a plug near the RH wheel hub in the sensor loom and that seems to be the source of many of these problems, a look and clean of that would be a good starting place. There are a number of Google instructions for checking the function of the wheel speed sensor by spinning the wheel and checking the resistance at the plug on RH hub. Better to check the sensor than just replace it. If you had a new sensor 3 years ago you would hope that it is not the problem. Clean and remaking all the plug connections is a worth a try.
Posts: 14 |
Broken wire it was - easy fix, thanks
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
That was happened to me Broient wire
