Topics49,871
Posts837,681
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
RichardV8 made a good suggestion, photo the position of the connection so the cables return to oem location.
I use a dental tool to release small latches like this.
Posts: 492 Likes: 11
Posts: 492 Likes: 11 |
Thanks both.
I learned the hard way to start taking photos of the project before I start pulling things apart. Now my phone is full of them.
I hadn't thought about the dental tools. Good tip. I do have some for some smaller jobs so I may check out if one of those will work. I ordered a cheap set of tools from Amazon for $10, just to suit future needs as well.
Thanks, Craig
Craig - Texas, USA 2026 Plus Four 2021 M3W
Posts: 398 Likes: 1
Posts: 398 Likes: 1 |
For headlamp bucket try 7in Dietz headlamp bucket I have replaced both of mine due to stress fractures around the mounting points. Much more cost effective than oem units Available in Black or Shiny
For headlamp bucket try 7in Dietz headlamp bucket I have replaced both of mine due to stress fractures around the mounting points. Much more cost effective than oem units Available in Black or Shiny Excellent suggestion. This may be a quicker way to source some replacements than getting them directly from Morgan. I am assuming that they will fit any standard 7in lamp, so they should fit the Blackout LED lamps I've added to mine. Also interesting to hear that I am not the only one who has had cracks. I was finally able to get off my headlight bucket and it is cracked on both sides wrapping around the back, almost 80% of the circumfrance of the base. It would not have not made it much longer.
Well darn it, I better go look closely at mine!
