1 members (CraigL),
293
97
Topics49,870
Posts837,667
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
this thread has prompted me to go ahead and order a fuel pump!
Posts: 121 |
I bought my parts from Summit Racing (summitracing.com). I ordered: - Walbro Fule pump part no #GSS342BX - Installation kit #400-766 - hose # TF0001275 (these are cheap and you may as well order an extra in case you crack or stretch this one)
I have considered using a submersible hose from Gates instead of the convoluted one above, but have not changed it out yet.
Thanks Joejoe!! Just ordered all these parts from summitracing. 400-766 is back-ordered. Hopefully it will arrive soon. I noticed that the part for the pump GSS342BX ends with BX which I have not seen mentioned previously, is that a different version of the GSS342 pump, which is usually mentioned on the forum. What is the difference?
2017 Terracotta 3-Wheeler + G56 Stage 1 (SOLD)
Posts: 121 |
Ordered a second #400-766 installation kit from walbrofuelpumps.com - since summitracing shows back ordered.
yes I got the back order thing as well. It looks like they order the fuel pump, so they must not have in on the stock shelf.
They will probably think it odd that two people ordered that pump in one day
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
Thanks Joejoe!! Just ordered all these parts from summitracing. 400-766 is back-ordered. Hopefully it will arrive soon. I noticed that the part for the pump GSS342BX ends with BX which I have not seen mentioned previously, is that a different version of the GSS342 pump, which is usually mentioned on the forum. What is the difference? BX means its boxed, that's all.
Posts: 121 |
Thanks Bruce. While I was waiting for the tow truck, I was thinking about your Mt Evans fuel pump story - atleast I was not at 14000 feet  I might ping you for some pointers when the parts arrive.
Posts: 257 Likes: 3
Posts: 257 Likes: 3 |
[/quote] Thanks Joejoe!! Just ordered all these parts from summitracing. 400-766 is back-ordered. Hopefully it will arrive soon. I noticed that the part for the pump GSS342BX ends with BX which I have not seen mentioned previously, is that a different version of the GSS342 pump, which is usually mentioned on the forum. What is the difference? [/quote]
It took me a couple of hours the first time I completed the job. I would say over an hour of that was figuring out how to get the 2 fuel lines separated from the inlet/outlets at the top of the housing, as well as figuring out how to get the 2-piece black plastic cover off the top (and removing the silicone goo that was on there). I had to go back and reclamp one of the internal hoses after I had completed the job, which was essentially the same disassembly, and it took me 20 minutes tops. Once you have done it once, it is probably a 30-45 minute job. The linked instructions are excellent, but the first couple of steps are fiddly and more obvious once you actually do it. Feel free to ask questions.
Aka Joejoe
Summit has now shipped me the pump and the hose, it looks like the wiring is back ordered
Posts: 365 |
It took a month or so for me to get everything from summit but it eventually arrived. I am saving this for a nice winter project.
Ken
2017 M3W Sport Green
