2 members (JohnHarris, Julian BB), 145 guests, and 87 robots.
+8Rich 78
Topics49,872
Posts837,690
Rudolf
Page 3 of 4 1 2 3 4
Dani Offline OP
Yeah
that looks fantastic. Thank you a lot for help!!
Is this original or is it a custom model knob?
4/4 Sport 2011
Dani Offline OP
Omg
That is really tight.Do i turn the knob it the right direction?
Its normal? To the left to lose, right?
4/4 Sport 2011
Lefty loosy
Righty tighty
Dani Offline OP
Thank you!
OMG such a stupid construction. All mounted wit a lot of screw glue.
But its done now. Hope i can get well again in.
What a crap. Sorry
Now i have to find a way to get the Kardan tunnel Leather fixed.
Also really bad done!
4/4 Sport 2011
good news that you have succeeded.
If you need to replace the gear knob, they come from “Richbrook”” and are supplied with a range of top decals to suit the shift arrangements of different gear boxes.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Dani
Sounds like they assembled it with Loctite, may not be MMC to be fair as they do sometimes work a little loose. If you have a hot air gun you can soften some grades of Loctite to assist cleaning it all off before you reassemble.
Well done
Colin
BR Colin
Or this one from Halfords is good @ £9.99 smile
Craig Jezz
Dani Offline OP
Thank you all a lot!
i like the original gear knob design.
My problem is just the cardan tunel cover.
There are to cuts in. One from the handbrake and one from the gear mechanism.
Than also the heat protecion stuff is just crap.
I dont know after just 20.000 km i have now to repair this.
4/4 Sport 2011
Blimey that looks bad. After 16 years and 47,000 miles mine is fine as were my previous cars. Could it be insect damage?
I am glad we helped you get it apart
Dani Offline OP
No it is just bad work.
I seems that the cover not fit straight on the tunnel maybe it needs more points that it stays in Position.
When i drive the car it is always blowing up.Looks stupid and i thing that was the reason why this the heat protection stuff get lose and damaged.
The reason for my cuts in the gear box cover and handbrake cover is that the leather went in between the sharp edges of the tunnel and the shifter
also the handbrake mechanism.
I dont know. That makes me all a bit mhhhhh.
normally this should not be happend in my opinion.
But i dont know what i can do against that its not will be happend again.
Maybe take the fabric heat protection away an glue some heat protection stuff on the tunnel and then put just the leather on the tunnel?
With more ancor points.
i dont know is this foam stuff a heat protection or is it just foam to get it soft?
4/4 Sport 2011
Page 3 of 4 1 2 3 4
