1 members (Ian B), 336 guests, and 92 robots.
Topics49,847
Posts837,389
#657056 18/08/20 05:17 PM
IvorMog Offline OP
Got some water in the footwell after the car was left standing for 2 days in torrential Welsh thunderstorms with the hood up and a John Taylor cover fitted.
No sign of any leaks through the hood / cover but because of the uphill parking attitude it did occur to me that water might run down the wing and collect in the area to the back of the wing where it meets the footwell and bulkhead and seep through into the footwell.
The joint between the wing and the bulkhead seems particularly vulnerable to water collection and seepage.
Hopefully the photo shows the area and I wondered if that is a known leakage point and whether it should be sealed.
Thoughts please!!
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
TBM Offline
My John Taylor cover is just under 2 years old, but is no longer waterproof. In the last few downpours it's been very ineffective. It does dry out pretty quickly though.
Yesterday gave it a going over with a litre of fabsil so hopefully that will improve its water resistance.
Not wishing to spoil the party, but you are right to ask as that spot CAN be a source of water ingress in to the frame.
I know that DaveW did an item on it in one of the MSCC ‘Miscellany’ magazines a couple of years ago, & there is also a section on “prevention” in his excellent ‘Modern Morgan’ book 👍. (Is this enough references, DaveW? - we know how modest you are🤗)
ArthurSBell
N44MOG Rolls Royce Green +4
M22ASB Grey Renault Megane Cabriolet
M10SAB White Fiat 500
Thanks Arthur!
Use Captain Tolleys in the corners. If that's where it leaks, it will seal.
If you'r a dab hand with a mastic gun you can squirt a bit of translucent mastic in there.
1994 +8, BMW Calypso Red.
How do you open the boot?
I've always applied sealant to all mine there.
Nick
Captain tolleys is a great tip! Thank you!!!
2018 +4, persian blue
Originally Posted by DaveW
Thanks Arthur!
Ahoy mateys arr that's the stuff
Thanks Arthur!
They picked some up in Dartmouth for the Mayflower Dave remembers it well wink
IvorMog Offline OP
Thanks all.
With the amount of water in the footwell, I think I'd better order another bottle of Captain Tolleys Creeping Crack Cure although I would have thought sealing with a flexible mastic would be better.
I'll try CT first then mastic if that doesn't do the job.
Bob
2009 Black Roadster
