1 members (tommog), 223 guests, and 72 robots.
+8Rich 82
Topics49,849
Posts837,425
#657436 20/08/20 06:38 PM
When I picked up my car one of the sliding windows had the perspex knob missing. I have now obtained a replacement to fill the hole but how should it fit? is it just a tight fit or should it be glued in & if so any idea as to what is best?
One of mine falls out occasionally and I use a tiny trace of superglue.
Don't overdo this or it will make a mess of the perspex. Use a cocktail stick or similar.
I think they have a little step on them to prevent them going right through and lining up with the rest of the screen.
That’s correct. I used some clear araldite as that’s what I happened go have available and it has been ok for the past couple of years. As already mentioned, apply sparingly or you’ll see it as a smudge.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
A thin smear of superglue stuck mine back in when it fell out. I use the gel type of superglue which is easier to control.
Super glue and care works
This is what I used when my perspex knob fell out. Worked a treat - Serious glue
