3 members (Gordon D, MJF, sewin),
145
43
Old Book
Topics49,940
Posts838,598
Posts: 12 |
Hi I have a recently acquired 1981 4/4 (1600Crossflow). It's in great condition, having had a complete rebuild - pretty much as new, and we are trying to iron out a few little niggles. My question, and please be patient, as I am not proficient with spanners, is to do with the Camber angle. My handbook states that the camber angle should be 2 degrees, but it does not say whether that is positive, ie top of the wheel leaning out, or negative, leaning in. My car is leaning out by precisely 2 degrees. Is that correct, or should it be leaning in?
Instagram @eastertown 1980 Morgan 4/4 1988 Morgan Plus 8 Porsche 986 Boxster S
Posts: 8,716 Likes: 421
Posts: 8,716 Likes: 421 |
You want negative camber, i.e. top leaning in. Later cars have adjustment for this at base of kingpins which have rounded ends to acommodate.
Posts: 1,415 |
2 degrees of positive camber is correct for your car. Zero would be more preferable with modern radial tyres It can be adjusted by heating the top frame lug where the kingpin is bolted in, and using offset “camber plates” at the bottom of the kingpin It’s not a job for the amateur, and the track rod between the wheels may need remanufacturing to be longer, so as to allow the correct toe angle to reset
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
Im guessing my 1956 plus 4 needs the same on CROSSPLY, the steering is a little stiff and I believe I have too much toe in, any measurments for toe in ..perhaps 1/8 inch? measured on yhe fron and rear radius of the wheels? I may look at the roller bearings to fit under the coil springs..or just some lubrication. IMG_6688 by Robert & Ali Davies, on Flickr
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
Article on the subject here.
