7 members (Doug J, brownbaker, ChrisNP, RichardV6, DCH, Nickplus4, JMcL), 136 guests, and 19 robots.
John V6 63
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,602
greenteagod
#663403 21/09/20 02:43 PM
E
E
Hi
I have a recently acquired 1981 4/4 (1600Crossflow). It's in great condition, having had a complete rebuild - pretty much as new, and we are trying to iron out a few little niggles. My question, and please be patient, as I am not proficient with spanners, is to do with the Camber angle.
My handbook states that the camber angle should be 2 degrees, but it does not say whether that is positive, ie top of the wheel leaning out, or negative, leaning in. My car is leaning out by precisely 2 degrees. Is that correct, or should it be leaning in?
Instagram @eastertown
1980 Morgan 4/4
1988 Morgan Plus 8
Porsche 986 Boxster S
Online NoMood
You want negative camber, i.e. top leaning in. Later cars have adjustment for this at base of kingpins which have rounded ends to acommodate.
Originally Posted by Eastertown
Hi
2 degrees of positive camber is correct for your car.
Zero would be more preferable with modern radial tyres
It can be adjusted by heating the top frame lug where the kingpin is bolted in, and using offset “camber plates” at the bottom of the kingpin
It’s not a job for the amateur, and the track rod between the wheels may need remanufacturing to be longer, so as to allow the correct toe angle to reset
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Im guessing my 1956 plus 4 needs the same on CROSSPLY, the steering is a little stiff and I believe I have too much toe in, any measurments for toe in ..perhaps 1/8 inch? measured on yhe fron and rear radius of the wheels?
I may look at the roller bearings to fit under the coil springs..or just some lubrication.
[Linked Image]IMG_6688 by Robert & Ali Davies, on Flickr
Triumph Herald 1969 13/60
Morris 1970
Online NoMood
Article on the subject here.
