0 members (),
395
74
Topics49,867
Posts837,614
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
While under my M3W the other day I noticed the adjustment mechanism on the parking brake cable (my parking brake is lever that amuses, but does nothing). Of course the adjuster is in a place that tempts you with seeing it, but totally inaccessible and therefore useless.
I am wondering if it might be accessible by removing the center piece where the lever and shift knob are located?
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
Rodger,
On my car the adjuster (a cylindrical device) is located in the driveshaft tunnel area about 8-10 inches behind the brake lever and is accessible from underneath. Though it is easier to adjust with the driveshaft cover removed.
Once properly adjusted the handbrake works pretty well, in my experience.
Steve Late 2012 M3W
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
My handbrake works well too.
Yes I can see it in the tunnel, but am unable to get at it to adjust. I will try taking off the center piece this weekend..... in between laying pavers for a back deck.
Posts: 1,947 |
I assume you know its a fly off handbrake, to set pull back on lever & press the button. To release pull on lever & let go. Do you say it does nothing because it does not hold the car when set? I initially did not like the fly off action but soon got used to it. When at traffic lights I tend to just pull back on the lever but not press the button. As an Engineer it annoys me when people set the hand brake by just pulling back in the lever & not holding the button in, this wears the ratchet.
I do realize how it works. It does nothing as it does not engage the brake enough to stop the car from rolling away (I do always park in gear)
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
I love the fly off handbrake, l wish the Mazda had it.
Posts: 4 |
OK on my 1988 4/4 the Fly Off does not hold for the majority of the time and would appear the Ratchet is worn or is there a Spring which is weak? Without a major strip down of the Tunnel is there enough access through the side hole and is there a fix that can be done? Taking it in for a Waxoil next week and when on the Ramp what should I be looking for from underneath?
Looking at a picture of the assy with the Tunnel removed it looks like the Pawl should simply lift out from the Ratchet by taking off the Knob, ....correct? Which wears first the Ratchet or Pawl, is there a service kit from Morgan?
