Topics48,338
Posts812,948
Members9,203
Posts: 26,747 Likes: 419
Posts: 26,747 Likes: 419 |
I prefer the trad set up at the rear but modern Mogs are better designed.
Posts: 7,893 Likes: 241
Posts: 7,893 Likes: 241 |
Just a quick post with a real-life experience for anyone reading this thread considering the 5 link. I had the front SSL kit fitted to my Plus 4, which made a big difference and was good value for money. The rear, however, which was fitted a month later, was a complete waste of money. It made practically no difference; if anything, the ride is slightly harder and I preferred the car as it was.
It may be that my (2019) car had a relatively decent ride quality anyway for some reason such that I didn't notice the difference, whereas an older car would benefit more the 5-link. I don't know, because mine is the only Morgan that I've ever driven. In any event, the rear 5-link is certainly not transformational, which it should be for the money. I wonder if the rear has been set up properly, having compared a leaf sprung car to a SSL rear even just pressing on the back of the car the springing feels markedly softer
Posts: 19 Likes: 1
Posts: 19 Likes: 1 |
The work was done by Williams so I've no doubt that it was a proper job and properly set up.
The work was done by Williams so I've no doubt that it was a proper job and properly set up. Fair point, Williams should know their stuff, does yours have the adjustable shocks ?
Posts: 19 Likes: 1
The work was done by Williams so I've no doubt that it was a proper job and properly set up. Fair point, Williams should know their stuff, does yours have the adjustable shocks ? Yes, and apparently adjusted to a medium setting.
Personally unless you're a regular trackday yoof, I'd try them FULLY backed off to soft & the fronts too (the front can have a surprising effect on the rear end feel)
Posts: 19 Likes: 1
Personally unless you're a regular trackday yoof, I'd try them FULLY backed off to soft & the fronts too (the front can have a surprising effect on the rear end feel) Thank you - that advice is gratefully received.
Posts: 1,793 Likes: 47
Posts: 1,793 Likes: 47 |
Personally unless you're a regular trackday yoof, I'd try them FULLY backed off to soft & the fronts too (the front can have a surprising effect on the rear end feel) - I agree - unless you've got it on the softer setting, it'll feel as solid as the leaf springs.
Posts: 1,799 Likes: 3
Posts: 1,799 Likes: 3 |
I don't see that the dampers will be the differentiator between the leaf spring back end or the 5 Link.
You can just as easily soften the dampers to make a leaf spring set up slightly more compliant but as I see it the spring rate is the spring rate regardless of the type of spring.
And also, they both still use a solid axle so no difference there.
Unsprung weight maybe?
What am I missing?
This assumes a properly located leaf spring setup. Panhard rod and maybe anti tramp bars on higher powered cars.
Bob
Posts: 7,919 Likes: 216
Posts: 7,919 Likes: 216 |
Surely coil springs offer better compliance to road surface changes given as you mention, lower unsprung weight but more importantly less friction in their movement. Even a single leaf spring suffers from the friction of its shackles.
